Engine coolant won’t drain
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jacob Nathaniel, Mar 6, 2019.
  1. Jacob Nathaniel
    Jacob Nathaniel New Member
    Reseda ca
    I can’t figure out how to drain the engine coolant from my 2016 Prius two. I opened the yellow drain plug on the bottom of the radiator and it only drained the fluid in the inverter reservoir. I also disconnected a hose on the very bottom of the radiator on the passengers side and that also drained the inverter reservoir after I had filled it back up. Please help. Thank you
  2. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    amos likes this.
  3. Mendel Leisk
    38,729
    Yeah the front radiator houses both the engine and inverter radiator, so you've got to be careful. I'd suggest to get a short term Tech Info subscription and download the info before proceeding. As far as I know there's no "repair manual" pdf for 4th gen.
    kithmo likes this.
