Engine cooling fan not working, pls help!
Discussion in 'Prius v Technical Discussion' started by MM.87, Aug 19, 2024 at 11:03 PM.
  1. MM.87
    MM.87 Junior Member
    Hi.
    I have a 2013 V w/ 337k miles.
    Engine cooling fan stopped working a few weeks ago. AC is not cold unless the car is moving 30MPH+ and if it is a hot day with a lot of stop and go traffic the high temp indicator will come on, so I stopped turning the AC on since last week. Coolant is boiling/gurgling but no coolant loss. No DTC codes. Fan relays 1, 2, and 3 were tested and they are all fine. A Bi-directional scanner couldn’t turn the fans on. The cooling fans used to be on and on mid-high speed all the time w/ or wo/ AC on. I’m still using the car daily. Please share your experience. Thank you!
  2. MAX2
    MAX2 Junior Member
    34
    Third Rock from the Sun
