engine cooling fan?
Discussion in 'Prius c Technical Discussion' started by Javierz0509, Jul 5, 2018.
  1. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    Hey guys I have a 2013 Prius C, today I noticed that my AC was not cooling while the car was parked, I popped the hood and also discovered that the engine cooling fan was not turning I checked the fuse and relay and everything was good so I decided to tap the center of the electric fan motor and it started spinning does this mean that is giving out? I've done this twice to have the fan spinning again.
  2. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    I don't know exactly but according to my information in Prius C Radiator FAN (or Engine Cooling FAN) is DC. Your FAN motor is not getting its initial torque required to start the FAN. Maybe its bushing deteriorated. You have to inspect the FAN motor in detail for problem identification.
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Appears the compressor maybe having some kind of bearing failure signs there. Do you hear any sort of salient grinding noise when the AC system is operating?
    Try checking the HV connector on the compressor stator, for partial connection problems.
  4. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    not at all no noise and the AC is ICE cold when the fan is working how is suppose to.
    is not the compressor.
  5. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    thats what i was thinking, and no i havent really taken it out to check it, i think ill have to remove bumper cover for that.
  6. bisco
    49,490
    how many miles on her?
  7. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    sorry for late response car has 138k miles, i also purchase the cooling fan assembly and i was wondering if there is any DIY instruction on how to do it?
  8. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    The cooling/condenser fan not running will certainly cause it not to cool. Easiest way to check it it to verify voltage to the fan when it's switched on, and also check for voltage on the ground side of the fan (should be zero). If that's in order, and it's not coming on, it's the fan that needs replacing.
    ztanos likes this.
  9. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    i replaced the engine cooling fan its all working now, thanks.
