engine failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bobarnold, Nov 12, 2004.
  1. bobarnold
    bobarnold Guest
    My combustion engine stopped working. The master warning light and engine icon appeared on the dash. The warning symbol appeared on the GPS screen. I was able to get to a Toyota service dept. on battery. I learned Toyota has sent a bulletin to dealers providing a "fix" for my problem called "ECU Update EG4017 perform TSB EG047-04." Part #89661-47071. My Prius is a 2004 and was covered under warranty. The service guy said no recall notice was sent to owners because the problem doesn't occur in all cars.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    That stinks, glad they got you fixed...you couldn't, by chance, get a copy of the EG4017 could you? Be good to see it here.
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Why is this message in this forum which is dedicated to issues regarding posting on this board? I would think that it belongs in the Care, Maintenance & Troubleshooting forum.
  4. efusco
    19,891
    1,192
    Nixa, MO
    So Moved!
  5. tag
    tag Senior Member
    2,526
    Chicago
    Damn these threads are heavy, aren't they?
  6. karmavore
    karmavore New Member
    65
    Madison, WI
    Is it just me, or has there been a palpable uptick in the number of reports of failing Prii?
    Assuming yes, I wonder if cold weather has anything to do with it, or if this is just what one would expect with more Prii on the road.
    Anyone else have any thoughts? On this, I mean. :)
    Brad
  7. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    The same thing happened to me last week, my report is in the post "First Breakdown." How is THIS for ironic timing: today the perky and cheerful receptionist at my local Toyota dealer called, asking if I could bring in my Prius "at your earliest possible convenience" as there MIGHT be the possibility of my ICE quitting. I can laugh about it now ...
  8. tag
    tag Senior Member
    2,526
    Chicago
    Yes.
    Errrrrr, no............no, not on this. :p
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ummm not your imagination at all. there has been an uptick of failures reported...
    couldnt have anything to do with the fact that there are now many more 04's and up on the road now as compared to before would it?
    NAH!!!
    the thought that my Prius wasnt a perfect car would be very traumatic to me...
    but then again, as far as i can discern, it IS a perfect car...
    knock on environmentally-friendly, oil-free plastic~~!!
  10. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Well your car, Dave, truly is perfect. When Priapus grows up, I hope he's just like your car. :)
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    thank you Tony...
    it swells me with tremendous pride to know that my Prius already has a small fan club....
  12. jpb
    jpb Junior Member
  13. richard schumacher
    7,663
    1,038
    United States
    Anybody know what this TSB (EG047-04) fixes? The TSB itself gives very little clue.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  15. jchu
    jchu New Member
    1,063
    Nampa, ID
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i agree... great link. definitely a saver.. .
  17. richard schumacher
    7,663
    1,038
    United States
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"50359)</div>
    Well, yes, but I wonder what is the broken functionality? And why doesn't it affect all cars? It makes me nervous to see something that gets fixed only if the owner notices a problem; it feels like a time bomb with a randomly-set detonator.
  18. TonyPSchaefer
    14,816
    2,497
    66
    Off topic post to follow:
    What happened to BobArnold?
  19. bbangert
    bbangert New Member
    Maybe this is also related to my break-down tonight. I have had several times in the past where I turned on the power, and it almost appeared on, but the engine failed to start. I had to keep hitting power, and turn the car off and on sometimes up to 6 times before the engine turned on.
    Since I still have the check engine light on, I'll see what the service center says tomorrow.
  20. bbangert
    bbangert New Member
    <div class='quotetop'>QUOTE(karmavore\";p=\"50016)</div>
    I think you'll see more reports of issues for 2 reasons.
    1) There's more Prius vehicles on the road.
    2) We are the beta testers.
    There will never be a final version unfortunately, as every new Prius model will have so many "improved" electronics systems they will generate completely new problems.
    Currently the Prius is bleeding edge, so we will be the ones amongst friends with humorous (or not) stories to tell of our computer car issues. Changing vehicles would only be a temporary reprieve as all vehicles are getting more and more computer systems in them.
    Someone might point out, "hey, the older Prius model has less issues" or that this is not the first Prius Toyota has made, which is true. However, given the complexity of the increasing electronics systems in each new model, I think future models may have even more problems they cannot account for in their testing.
