engine flapping sound
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Chabelo, Oct 31, 2014.
  1. Chabelo
    Chabelo Junior Member
    24
    Valley Springs, Ca
    2014 Prius Plug-in
    Occasionally when my ICE starts up (typically when cold) there is a brief "flapping" sound, very remenescent <sic> of when I attached playing cards to my spokes with a clothespin... Is it normal? (car has 8k miles)
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Sad to say but it is normal, especially if you start the car to move it a short distance (driveway to garage for example), turn it off before the engine completes it's warmup cycle and then let it cold-soak over night.
    The two typical workarounds are to always let the engine complete it's warmup cycle, or once it is knocking on startup floor the accelerator.
    49,371
    there is no need to let your ice start for a short time such as moving around yard, unless you let it run all the way down. in that situation, i always make sure i'm within charging range before starting.
  4. hill
    8,153
    I think the sound (s)he's hearing is that of the electric vacuum brake canister recharging - which is normal regardless of the battery's SOC .
  5. bisco
    49,371
    why would they only hear it when the ice fires?
  6. hill
    8,153
    do not know . . . I seem to here the one on our hybrid Lexus most frequently when any of the doors are 1st opened in the morning.
    :confused:
  7. bisco
    49,371
    that's when i get it to, that buzzing sound. only my drivers door does it.
  8. -Rozi-
    -Rozi- Member
    134
    59
    Slovenia, E.U.
    2014 Prius Plug-in
    Although it's not the situation the OP described, I am grateful for this information. Now, I know what this buzz after I open driver's door is.
  9. bisco
    49,371
    that's funny, i thought everyone knew the latest buzz.:)
    retired4999 likes this.
  10. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    I hear this "flapping" sound every day when I manually switch over to HV mode while pulling onto an on-ramp. (already traveling at some speed) If I am stopped at a stoplight and make the change, I don't hear the sound. It seems to me that it is related to vehicle/drivetrain speed and load when the ICE is activated.
  11. bisco
    49,371
    i would make the switch a few minutes before the ramp.
    markabele likes this.
  12. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    Meh... It doesn't really bother me, just adding a point of reference.
  13. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    It was 10 below zero yesterday morning. I moved the car out of the garage to make room for some wiring for a portable generator installation. Later in the day, I started it up to put it back in the garage and it sounded like a freaking cat was flopping around under the hood. It sounded like hell. I've heard it once before several months ago but it only lasted 2-3 seconds, immediately after starting the car. I've been worried since yesterday's experience, wondering if it would make it to the dealer, or if I should even take it in to have the dealer look at it. ???
  14. bisco
    49,371
    no, don't bother, it's a known issue with no fix. but here's the good part, you can move it around in ev, unlike our lift back brothers, so you can choose to avoid the situation.
  15. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    "it's a known issue with no fix..."
    Does it cause any permanent damage to the engine or motor mounts? If so, that would bode for Toyota covering repairs in the future (even after warranty) due to this apparent design flaw. Unless anyone has reported either engine or motor mount failures, it's more an irritation than a problem.
