Engine getting louder
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dilbert, Oct 19, 2006.
  1. Dilbert
    Dilbert Junior Member
    44
    Seattle
    The engine noise at high RPM has been getting louder on our 2004 Prius with 21K miles. Almost like a bad muffler. Anyone else have this happen?
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :mellow: Hi Dilbert
    My 2004 has just under 22,000 miles on the clock. I have not noted any change in ICE sound as the miles increased. My only real noise issue is with the OEM tires, particularly on rough pavement; however, since I keep my radio tuned to my favorite Classical station, this tends to mask some sounds.
  3. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    <div class='quotetop'>QUOTE(Dilbert @ Oct 19 2006, 12:25 AM) [snapback]334917[/snapback]</div>
    Are you sure? Noise at a given rpm should not change, but with colder weather it should run much more at higher and noiser rpms.
  4. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Dilbert @ Oct 19 2006, 01:25 PM) [snapback]334917[/snapback]</div>
    Please visit your dealer to find out the root cause of the problem.
    Ken@Japan
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Dilbert,
    Great to see you again. Dude, you really need to come around more often. :D
    Since it's an '04 and you've been through a couple winters like Charles, Ken and I have, I'm going to assume that you're not talking about a cold engine working a little harder. With 20,250 miles, that's all I notice but only during situations like dead-stop acceleration.
    Until you take it to the dealer like Ken suggestions, let's do some troubleshooting. Have you had someone run the ICE while you're standing outside the car to help locate the source of the noise? Are there any situations in which the noise is present or more noticeable? What is the air-speed velocity of an unladen swallow?
  6. Dilbert
    44
    Seattle
    Yes it has been a while since I last posted, just busy I guess. The engine sounds fine at idle and regular driving. It is only when you put the pedal way down to climb a hill that it gets louder, and I mean louder than it used to. Even my wife commented about it without me asking. I better get it in to the dealer.
    Thanks for the help.
  7. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Oct 19 2006, 09:15 PM) [snapback]335365[/snapback]</div>
    What do you mean, an African or European swallow?
  8. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    How does he know so much about swallows?
  9. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(john1701a @ Oct 20 2006, 06:47 AM) [snapback]335496[/snapback]</div>
    When you are a king, you need to know these things.
  10. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(bhaynnes @ Oct 20 2006, 11:14 AM) [snapback]335595[/snapback]</div>
    Bahhhh, so close, and yet so far...
    Well, you have to know these things when you're a king you know.
  11. chrisg67
    chrisg67 New Member
    31
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 20 2006, 12:54 PM) [snapback]335615[/snapback]</div>
    STOP everyone know a one pound bird cannot carry a 2 pound coconut.
