Engine issue
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, May 7, 2025.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    Hello. My '06 Prius has been eating up a lot of engine oil and I was wondering of which years' Toyota Aqua/Prius C engines could work with it to replace the original engine. I heard that the Aqua/Prius C engine works better on a 2nd gen Prius and doesn't eat up nearly as much oil.
    I keep having to add about 4L of engine oil every 5k miles. The engine works well, MPG is fine, but there is a strange sound when going uphill. The car has 133k miles on it and the engine never needed any repairs. What do you recommend I do?
    Thank you in advance.
  2. ChapmanF
    17,264
    Hmm. I believe the Prius c engine comes with a variable-speed electric water pump, which the gen 2 ECM won't know anything about, and the gen 2 wiring harness won't have any wires for.
    So you could need to improvise something to make that work ... or just swap in a belt-drive gen 2 water pump, if the mounting is the same, which wouldn't surprise me.
  3. PriusCamper
    PriusCamper Senior Member
    12,018
    4,882
    Pacific Northwest, USA
    Based on what @ChapmanF is saying I don't think it's possible.
    It seems odd that such a low mileage engine would have an oil burning problem that's this bad. Probably most lasting and fastest solution would be to swap the engine out with a low mileage used one from a vehicle at a wrecking yard. It's a very straightforward job as far as engine swaps go:
