Engine keeps Knocking and shaking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by smokeGTI, May 19, 2021.
  1. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Hi All,
    The car is 2009 gen 3 prius with est. 155,000 km on it.
    Oil and filter changed, throttle cleaned just less than 2000 km, I put half bottle of STP fuel injector cleaner
    to the car while filling half tank to full. Nothing happen, when it's almost empty, then I filled with full tank
    of gas, then ran for approx 100 km.
    Then a day after, i went out to pick up something, when I was driving back home start the engine, go for about 1 km, the car start shaking and then knocking sound was heard (the car was fully warmed up). So the car was towed to home, then code scanned, nothing shown.
    I have cleaned the EGR pipe, valve and cooler, cleaned all injectors, replaced new spark plugs and air filter.
    Then I fire it up, no change, and It has error code this time P3190.
    So the only thing that I can think of is cleaning intake manifold and throttle body.
    What do you guys think ? Any experience with this issue ?
    TIA.
    ANDRAS RIMELY likes this.
  2. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    (y)
  3. Mendel Leisk
    40,583
    Yeah definitely clean the intake manifold, paying particular attention to the Exhaust Gas Recirculation passages: one large inlet and four capillary exits, one at each engine port.
    if shaking persists: leak down test to determine head gasket condition.
  4. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Thank guys,
    Will go for intake / throttle / MAF cleaning first, and finger crossed.
    Hope not the blown gasket.
    Thanks for the helpful info's. too. (y)
  5. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    if you want the knock to stay away, get yer cash canner reddy.
  6. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Quick update, problem solved!
    Was playing idle in P/D/R/N, and it finally throwing a pending misfire code on Cylinder #3.
    so I swap #2/#3, and the misfire code shifted to #2.
    So replace all coils as they are old anyway. problem solved.
    Thank you all.
  7. bisco
    51,154
    nice going!
