Engine knock @ 119,820 miles on a 2013
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Feb 6, 2024.
  1. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    Hi PriusChat
    I got my first long Engine Knock today and last about 25 sec. and the engine shaking. SoCal weather has been raining last 3days, but NO flood in my area. Outside weather Temp this morning about 50 F
    My Prius Spec
    Yr 2013, 119,920 miles. Daily commute 20-25 miles per day.
    Oil Change every 5000 miles
    Last EGR Valve and EGR Cooler clear @ 99,200
    Oil Catch Can installed @ 98,500 and drain 2-3 teaspoons out on every oil changed.
    What should I do next to prevent further knock before i arrange to change the engine gasket.
    twcctz500 likes this.
  2. sylvaing
    sylvaing Senior Member
    1,204
    512
    You might want to edit the title. I was wondering how you already had 119,820 miles on a 2023 Prius.
    twcctz500 and Mendel Leisk like this.
  3. Tekken
    Tekken Member
    257
    77
    Too late to edit Title.
  4. Mendel Leisk
    40,918
    Use the report button, ask moderator to fix.
  5. Mendel Leisk
    40,918
    The knock is very likely due to leaking head gasket, and the only thing that fixes that…
    Was there an earlier cleaning, and at what miles?
  6. Grit
    Grit Senior Member
    6,559
    4,222
    Wilkes Land
    Dam a 2023 that’s already knockin.
  7. rjparker
    rjparker Tu Humilde Sirviente
    9,825
    6,064
    Texas Hill Country
    The best thing is to diagnose quickly and fix hg if necessary, using a quality borescope inspection in the hands of an experienced mechanic. It is about the only reliable test early on in these cars.
    Not much you can do otherwise that is not a waste of money or does not cause other problems down the road. Assuming a head gasket is failing and you don’t want to get rid of the car quick.
    These engines don’t have classical hg symptoms like combustion gas in the coolant or coolant in the oil. Early stage hg leaks are rarely detectable with compression or leak down tests.
    First the waste of money options:
    Egr cooler cleaning (do it with the hg job); new plugs especially if already changed by the maintenance schedule (although this sometimes clears it for a week or two); new coils or injectors (waste of money unless they fail). If they fail they don’t clear up quick and run good for the rest of the day.
    Want to clear it for a month or two and end up changing the hg and radiator and heater and thermostat? Pour some block leak sealer in the coolant. Sometimes an extra bonus down the line is a bent rod, broken piston or hole in the block.
    If it’s an oil burner as well get a rebuilt engine.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    After 3 days of rain, I don't think jumping into a head gasket replacement is the first thing I would do. I've seen several cars that have a significant misfire for the first minute after starting after a decent rain. Would be crazy to jump into a multi-thousand dollar job that fast.
    Brian1954 likes this.
  9. Tombukt2
    Tombukt2 Senior Member
    12,631
    2,249
    Durham NC
    Look at the rest of the car really carefully Is this something that you want to try and keep another 3 years armrest door panels happy with everything about the car except the engine problem All righty then We were not so we did not. Funny story my wife thought she was and did and is turned out to be one of the most expensive cars we've ever owned and doesn't go anywhere The proverbial driveway queen so it just sits getting ready to get parted out although my other half sits there and tells me it's going to get fixed and it's going to ride again and I'm like yep well you'll need to get a better job to make that happen as you see what this is costing so it'll sit out here for 3 years and nothing will happen with it finally I'll get it to salvage after everything is falling down out of the car all around it some people just don't know when to say when and that's a very tough thing to have to learn.
  10. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    How about checking the coolant level? Simple, fast, cheap. If it's down that's a good clue for a bad headgasket. Mileage seems too low to be the head gasket, but you need to get it sorted fast and I wouldn't drive it that way.
    #10 MikeDee, Feb 7, 2024
  11. ASRDogman
    ASRDogman Senior Member
    7,390
    3,854
    DANGER DANGER WILL ROBINSON DANGER!!!!
    The more you let it knock, the more damage you are asking for.
    It can/does cause a rod to bend/break and possibly go through the block.
    And possible damage to the head.
    You should not drive it.
    You could try to put a vacuum on the coolant tank. Maybe the won't drip
    into the cylinders.
  12. Tekken
    Tekken Member
    257
    77
    Thanks all for great input.
    I ran a Torque code check and turn out it has Code P0303. ( #3 Cylinders misfire). No Engine light during the engine knocking
    I'm going to check the #3 spark plus and ignition coil. From the driver side, how can tell which is a #3 cylinder?
  13. Mendel Leisk
    40,918
    Sitting in drivers seat, cylinder one is on right end. Standing at front, cylinder one is to your left, next to engine coolant reservoir, timing belt cover.
    swap the coils/plugs and see if misfire code changes would be my first test.
  14. BiomedO1
    BiomedO1 Senior Member
    3,038
    1,620
    SacTown, Ca
    Cylinder #1 is the one closest to the timing chain/harmonic balancer. The cylinder closest to the transmission is #4. Since the event lasted only 25 seconds; I doubt you have an ignition coil or spark plug issue. This may be just a one-off, too much moisture in your oil catch can mod. Just monitor it and start saving for a head gasket replacement job. If this starts becoming more frequent, you should get the HG replaced as soon as possible - to avoid engine damage. Ditto, if the coolant levels begins to drop - it probably isn't noticeable now, since you caught it early.
    Good luck......
  15. Mendel Leisk
    40,918
    ^ Would be good to know. Also, was intake manifold cleaned?
  16. Tekken
    Tekken Member
    257
    77
    Intake manifold checked and cleaned evey year. Only concern I don't like there are still 2-3 teaspoon oil trap town @ throttle body even with Oil catch can.
  17. Mendel Leisk
    40,918
    Not oil catch cans are equally effective. And even the best won't stop it all. It's a fine mist, really flying through there; you waylay some, but not all. I've got a couple of Moroso 85474's, in series, and still there's a sheen at the intake manifold nadir.
  18. Tekken
    Tekken Member
    257
    77
    20240211_142535.jpg Have a chance to check #3 spark plus and it's seem oil moisture on cylinder #3. See spark plugs pic
  19. Mendel Leisk
    40,918
    The others are cleaner then?
  20. Tekken
    Tekken Member
    257
    77
    Here's cylinder#1 spark plug pic.. less oil moisture @ 120k miles.
    Spark plugs were changed @ 99k miles
    Should i replace a Denso SC16HR11. A newer version of Gen 3 prius spark plug Toyota recommended.
