Engine Knock even after cleaning EGR pipe cooler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Radiospank, Feb 28, 2021.
  1. Radiospank
    Radiospank Member
    169
    82
    Hiya,
    just cleaned my EGR pipe and cooler, pcv valve at 130k miles, I had bad rattle in the very cold mornings in Norcal, and so I decided to do the egr maintenance. However, I'm still getting slight rattle on cold mornings when I let my car idle or warmup, its minor compared to how it was but still. Whats next, should I clean the intake manifold? Should I change the head gasket? I'm thinking just live with it and if it goes then see yah.
  2. ASRDogman
    ASRDogman Senior Member
    7,948
    4,043
    The intake manifold is part of the egr system. There are small ports for each cylinder
    underneath the large ports for each cylinder.
    Yes, you do need to clean them. At least it's a lot easier and faster to remove and clean the intake
    than the egr valve. :)
    How clogged was the cooler?
    Raytheeagle and pjksr02 like this.
  3. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Do you mean the "PCV valve" or EGR valve? Many owners replace the PCV valve when the intake manifold is removed for cleaning.
    Radiospank likes this.
  4. Mendel Leisk
    42,119
    Cleaning at 130k miles, and AFTER symptoms arose, you might have left it too long.
    Definitely clean the intake manifold ASAP: all the upstream cleaning is for naught till you’ve cleared the Exhaust Gas Recirculation passages in the intake.
    You can check the condition of the head gasket with a leak down test. If you’re not losing coolant you may have caught it in time.
    Exhaust Gas Recirculation info:
    Bad Flywheel | PriusChat
    #4 Mendel Leisk, Feb 28, 2021
  5. Radiospank
    Radiospank Member
    169
    82
    CDAC775A-9774-4888-BE54-E6C99FEBF0F7.jpeg 59FCEFE0-ABEA-4B6F-AB45-9C8BDDAC0804.jpeg 26A36074-FFDF-4897-99D4-402963FD33B8.jpeg
    Don’t have any pics of the cooler cleaned but I did a quick soak in vinegar and baking soda and soap, then ran carb cleaner through it several times, finally power washed it which cleaned it out really well.
  6. Radiospank
    Radiospank Member
    169
    82
    Yes this has never happened to me before I moved to norcal which temps dropped in the 40s and so i immediately looked up why and it’s only happened 2 times on cold cold mornings, I tried the start the car in neutral for a few secs before putting into drive mode and that seemed to help quite a bit on those mornings to stop the shuttering, since then I cleaned the Egr pipe and cooler and PCV valve in hopes to get rid of this issue. No coolant loss was visible as I checked that knowing it was a probably head gasket leak; however I just changed out the coolant with this EGR service anyway so if it drops any I’ll know.
    mikey_t likes this.
  7. Radiospank
    Radiospank Member
    169
    82
    PCV valve was changed first from underneath the car a few weeks before the EGR cleaning.
  8. Mendel Leisk
    42,119
    A chemical cleaner that works well is saturated Oxi-Clean solution, with hot tap water. Cork one end and fill with solution, wait about an hour, rinse and repeat. Takes a few cycles, it froths up, eats away at the carbon. I’d only use it on the stainless steel cooler, since it’s moderately basic. Everything else can be readily cleaned with brake cleaner and brushes. For next time. :)
    Steph1972 likes this.
  9. ASRDogman
    7,948
    4,043
    Use the pressure washer first to clear it out, then oven cleaner. Oven cleaner is inexpensive.
    You can use "other" stuff, but oven cleaner eats the carbon build up.
    Then use the pressure washer to clean it out. It will take a few times before
    you'll have clear water going through, depending on how dirty the cooler is.
  10. Radiospank
    Radiospank Member
    169
    82
    Yea I read about all the different methods and oven cleaner seemed to be the absolute best but I didn’t have any on hand and only had carb cleaner, but I did carb cleaner and then power wash twice and then soaked in vinegar water and then power washed again and carb cleaned several times. In the end it’s clear straight through and flows well but for next time if there is I’ll def let it soak with oven cleaner .
    Steph1972, Mendel Leisk and ASRDogman like this.
  11. Radiospank
    Radiospank Member
    169
    82
    So I’m planning on doing the intake manifold cleaning but I’m curious for those that know if the head gasket repair is worth the hassle and maybe just scrapping the car is a better option? Or an engine swap with a low mileage engine?
    I just don’t want to invest too much money in an old 2010 Prius even tho I love my car :/
  12. ASRDogman
    7,948
    4,043
    I think it's a personal choice. You take a chance with a used engine. And I would try for a
    2015 engine because of the updated pistons and rings, and likely less mileage.
    It would be better to get a remanufactured or new short block and have the head checked
    to see if it's warped.
    Replacing the head gasket is the least expensive if you are going to change it yourself.
    Either way, it will take time.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    "My car rattles slightly during warmup on cold mornings. should I scrap the car?"
    Come on, man. Listen to yourself. :)
    I had a 2010 which I bought new. I sold it in mid-2012 to get the Plug-in which I still have.
    My 2010 had an odd cold-start problem: If I shut the car off before the warmup cycle completed, the next start would ALWAYS be a rough start. But if the car completed the warmup cycle, I would not get a rough start. The 2010 was the first year of the Gen III and had some issues like that.
    On the other hand, you just completed some important maintenance. If you didn't remove and clean out the intake manifold, then you still need to do that. There are pipe cleaner-sized passages which easily become blocked. But all you did was maintenance. Welcome to the club; we've all done it.
  14. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    Hello all,
    I have a similar problem so maybe it fits well in your thread.
    Hopefully some part of this brain trust of people like ChapmanF, Mendel Leisk and Ragingfit can help with my situation.
    Like Ragingfit I have a 2012 Prius v. However, I bought mine new from the dealer in April 2012. It now has 59,000 miles on it. 100% of factory recommended maintenance has been done so far mostly by the dealer. I do a few easy things myself.
    Over time my Prius has developed a kind of metallic rumble when under light acceleration.
    Most recently there has also been a nasty shaking occasionally at idle which I understand is transaxle damper rattle. Based on what I have read and having received Canadian EGR valve warranty extension notice W11 from Toyota I believe the transaxle rattle is caused by a sticky EGR valve which causes uneven firing in the cylinders especially upon start up.
    I tried Ragingfit’s idea of unplugging the EGR and there was a slight change but not the kind improvement that he found.
    I decided to change the plugs, renew the PCV valve, and clean out the intake manifold and EGR system.
    The plugs are a revised spec SC16HR11 Denso which run slightly hotter than my original SC20HR11. In the end I did not renew the PCV valve because when I arrived at my appointment to pick it up. I was told sorry someone else was given the one on order for me. The PCV was a simple metal spring loaded piston check which moved freely.
    My EGR cooler, EGR pipe and the intake manifold EGR ports all turned out to be dirty and partly restricted but none were fully blocked.
    My EGR valve is a 90 degree angle stop valve with a brushless electric motor drive to raise and lower the stem and there is a small spring to assist with shut off. After separating the EGR valve from the cooler and removing the black plastic stator cover and screwing of the rotor I found that yes indeed the valve had a bit of excess carbon deposit covering the stem and it was sticking in place. In my rush to get it moving freely I stupidly omitted to take note of the precise position it was in. I believe it was partly closed but not fully closed but this is not certain.
    I was able to clean a lot of the valve stem by fully compressing the small spring and scraping as much carbon from the stem as possible. By adding grease and opening and closing the valve by hand I was able to restore normal spring closing.
    A rhetorical question: Why make the EGR valve with stem pull up (SPU) closing rather than the more usual stem push down (SPU) closing? The only real advantage I see to SPU is pressure assist to shut-off in the fully closed position but it has the downside that the stem is fully exposed to the flow in the open position. This is only recommended for use in clean flows. Crud getting into the stem packing area is the natural result of particulate in the flow getting onto the stem which is then pulled up through the packing each time the valve closes.
    Under the Canadian W11 warranty enhancement program owners who have experienced a rough idle and/or tapping noise from the HV transaxle at cold start due to a sticking EGR valve due to excess carbon build-up is eligible for a warranty repair.
    I assume the Ragingfit unplug EGR solution applies best when there is more obstruction so that unplugging tells the control system correctly that the EGR is equal to closed.
    Question: Has anyone contacted the dealer after fixing the problem themselves? Will the dealer supply a new EGR valve?
    My other problem did not go away and must be a separate issue. There is still a metallic rumbling under light acceleration!
    Questions: Could the PCV valve cause this? Is it normal that the PCV valve piston feels quite loose or should the spring be keeping the piston tight against the valve inlet?
    The car has been very gently driven since purchase and I am the only driver. The only driving stress which comes to mind is a condition of my old daily commute. There is a long slight downhill slope and the car would go into electric only mode at 50 mph. At the end of the down grade as I pressed the accelerator pedal the ICE would come on but seemingly at a very low rpm. It was only a feeling since I do not have a tachometer. The low rpm may have put some stress on the engine but I did not find a way to avoid the condition and I assumed it was normal for a Prius being super fuel efficient.
    I doubt there would be a head gasket issue. The dealer seemed to fill the car at the high end of the scale but the feeling seems to be a rough rumbling rather than liquid knock in the cylinder though I am no expert.
    Question: Any ideas on the rumbling at light acceleration?
    Thanks for any Help
    Will
    #14 Willy Toast, Mar 4, 2021
  15. Radiospank
    Radiospank Member
    169
    82
    hah well I’m only saying scrap the car because the maintenance on the egr system is supposedly a band aid for the head gasket issue that will occur. Just finished cleaning the intake manifold and it wasn’t too bad I don’t think
    Here some photos after the first pass of cleaning, I later power washed it too
    Aaron Vitolins and ASRDogman like this.
  16. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    How badly clogged were the little egr holes in your manifold? Can't quite see in pic :)
  17. Radiospank
    Radiospank Member
    169
    82
    they weren't bad at all but I remember cleaning the one that attaches to the egr pipe prior to today's, I made sure to clean those little inlets very good as well.
    ozmatt likes this.
  18. ozmatt
    637
    263
    Australia
    okay that's good, #1 inlet was blocked solid in mine, other three were 70/80% blocked ..the pipe and cooler etc about 20/30% restricted, at a guess
  19. rjparker
    rjparker Tu Humilde Sirviente
    10,793
    6,774
    Texas Hill Country
    I think a going forward strategy depends on current oil burning, oil leaks, hv battery history, inverter and master cylinder status and how long you would like to keep the car.
    If I have a 2010 gen3 that burns oil, leaks, is beyond the ten year inverter and master cylinder warranties (without previous replacements), has the original hv battery, occasionally cold start rattles AND I am thinking about a newer vehicle within a year, then I might do do little besides moving the newer car date forward. Doing so may preserve my private party value in the 2010.
    If the engine and car is clean, no oil issues, the hv battery is hanging in there, I like it and want it to last two more years, then a head gasket now makes sense. I certainly would verify the hg with a leakdown test and block combustion gas detector.
    Maybe I love the car, have oil problems but have already put in a new hv battery, the master cylinder was replaced and I would rather put the down payment into my 2010 for a rebuilt engine and no ongoing payments, then I might get a used "low mileage" gen3 engine and have an experienced independent shop do the work.
    There are a spectrum of possibilities. By the way, the egr system is closed at startup and during initial warm up periods, so cleaning the egr cooler and passages before the cold start rattle is potentially preventative but is rarely curative after the rattles start.
    #19 rjparker, Mar 4, 2021
    Mendel Leisk and Radiospank like this.
  20. Radiospank
    Radiospank Member
    169
    82
    Currently the car doesn’t have any leaks or burning oil probs, still on original inverter and HV battery. I would probably just proceed with a head gasket change if I do it myself, otherwise rather just sell and get another car. I really like the Prius cvt and the mpg, it’s great! Sad Toyota let me down when I was expecting this to go 200+
