Engine knock on start--my theory
Discussion in 'Gen 3 Prius Technical Discussion' started by cobradb, Nov 23, 2010.
  1. cobradb
    cobradb Member
    105
    tn
    I once experienced the noisy eng start up.. it sounded like the engine was trying to run backwards or severe pre-ignition
    so here is my theory
    the engine has 13 to 1 compression based on what ive read.
    but this is reduced by the valve timing delay.
    What if the valve doesn't open correctly and the effective compression is 13 to 1
    This would be a very good chance for pre-ignition using 87 octane fuel
    just a theory and im sure there are the engine design folks could verify this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I suggested pre-ignition myself last fall when it happened to me. No one confirmed nor denied.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    If you have Scangauge II, check the IGN value when you are getting the knock. It should be a negative number during warm-up. I forget the exact number.
    2 people like this.
