Engine knocking at start up... Did not complete warmup cycle the previous night
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Roger T, Dec 30, 2014.
  1. Roger T
    Roger T Member
    198
    48
    MA
    As title.
    Sometimes I have to park my car two blocks away in the afternoon, and later in the evening i need to park my car back to the spots in front of my apartment.
    EV mode won't be enough to last the two blocks, even at 7 bars. Or sometimes the car won't let me turn on EV mode, even at 7 bars (battery too cold).
    So the engine must run if i want to park my car back near my apartment. But the two block distance will not suffice to completely warm up the engine
    So the next morning... (20~ Fahrenheit)
    My car knocks for a few seconds the next morning the car starts up...
    What is the definition of completing the warm up cycle? 120F? My car will turn off the engine after coolant temp reaches 120F (ECO mode).
    #1 Roger T, Dec 30, 2014
  2. JC91006
    16,482
    8,397
    I find my car turns itself off after about 1 minute. But I'm in CA, it's not that cold here. Next time when you are in your parking spot, just wait til the engine turns off before you shut down.
    Roger T likes this.
  3. Mendel Leisk
    38,712
    Was it knocking then, the next morning?
    49,456
    make sure the heat is off, then it will complete as quickly as possible.
    Roger T likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I don't necessarily see a problem here.
    You seem to be equating not being able to fully warm up the engine, in a short duration drive as being "the reason" your vehicle is then knocking on start up on a cold morning.
    Really, what options do you have? Either wait until the engine reaches temperature every time you use it, or not. If I'm moving from parking spot to parking spot, personally I'm just turning the vehicle off as quickly as possible and living with any possible knocking with the next start up.
    Unless the knocking is so horrible or of such a long duration that you suspect damage is being done, I'd just ignore the whole thing. I'd also suspect the "cold engine" knocking symptom will dissipate in Spring and Summer.
    It's winter, it's cold, and your engine is knocking for a few seconds on start up. I wouldn't sweat it.
    Roger T likes this.
  6. Roger T
    Roger T Member
    198
    48
    MA
    Yes, knocks for a few second the next morning. I read some old related threads. It seems like a common issue of knocking when car did not completely warm up the previous trip and the car is parked in the cold overnight.
    I hope to avoid the knocking! Loud and sounds harmful. I will wait until the engine shuts off itself to at least warm up the car a little more the next time in the short trip i park my car back to my apartment.
  7. Roger T
    Roger T Member
    198
    48
    MA
    Thanks for your response. So true. My car knocked for like 2 seconds at start up.
    I don't think it is a big problem either. Just hope to bring it up here to discuss about it.
    The Electric Me likes this.
  8. bisco
    49,456
    i believe it's unburnt fuel in the intake manifold. a redesign was supposed to help, but apparently not. still seeing problems. it's not a big deal, but i wouldn't want it happening everyday if it were my car.
    Roger T likes this.
  9. fuzzy1
    10,167
    More likely not the battery, but the engine coolant is too cold, below 68 degrees F.
  10. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Cortezz likes this.
  11. Roger T
    Roger T Member
    198
    48
    MA
  12. fuzzy1
    10,167
  13. bisco
    49,456
    yeah, unfortunately.
  14. Roger T
    Roger T Member
    198
    48
    MA
    It does not happen often... i only saw it happened once this winter.
    And in the previous night, i drive it for 30 sec then turn off the car when the engine is on... I think that's why it would happen.
    #14 Roger T, Dec 30, 2014
  15. Roger T
    Roger T Member
    198
    48
    MA
    Thanks for your comment. Looked up Ken@Japan's thread:
    S0:
    • it is from power on until the ICE starting for warming up (approx 12 seconds)
    • you can enable the EV-Drive Mode during this S0, if the conditions are allowed so (refer to your owner's manual)
    • the EV-Drive Mode can not be turn on when (1)the temperature of the hybrid system is high (ie; the hybrid battery is above 46C), (2)the temperature of the hybrid system is low (ie; the hybrid battery is below 0C), (3)the hybrid battery charge level is low (three bars or less), (4)the windshield defogger is in use or (5)the engine coolant temperature is below 0C (maybe 20C on the US Prius)
    In Mass here in the morning it is like 20~ degree F. Seems like both factors contribute to it. ;)
    So EV mode is more useful in the summer... :)
    #15 Roger T, Dec 30, 2014
  16. fuzzy1
    10,167
    ^^ Ken's point here:
    is the same 68F threshold to which I was referring. It is 68F (20C) in the U.S, 32F (0C) in most of the rest of the world. In my climate, this threshold locks me out of EV mode about 360 mornings per year. I've had little opportunity to explore a separate battery temperature threshold, my garage is nearly always above (barely) freezing.
    Roger T likes this.
  17. Roger T
    Roger T Member
    198
    48
    MA
    That got me thinking. Why does Toyota set a higher threshold for the US??
    #17 Roger T, Dec 30, 2014
  18. bisco
    49,456
    ah, the age old question...
  19. bisco
    49,456
    we suspect the u.s. legal system, but in this case?
  20. fuzzy1
    10,167
    I suspect it is related to our better hybrid battery warranty.
