Engine knocking noise, poor mileage, no codes
Discussion in 'Gen 2 Prius Technical Discussion' started by snowboarder, Jun 29, 2020.
  1. snowboarder
    snowboarder Junior Member
    Eden Prairie, MN
    I have a 2007 Gen2 with 296500 miles... So close!
    Does use oil to the tune of about 1 qt / 1000. Oil is topped up.
    The engine runs with a knock. It seems to be on the right side.
    Mileage down from 49 mpg to 36.
    No codes.
    Torque shows the battery is balanced. 16+ volts +/- 0.1v
    When first started and when running at higher RPMs the knock gets quieter.
    - At the same time when running faster Torque reports the HV current to be 4.2 Amp.
    When I let off the gas, Torque reports The HV current to be -21 Amps (in park)
    More pedal is required to maintain the same speeds.
    I looked through the threads and could not see any thing similar.
    There seems to be some electrical load kicking in.
    Thanks for any help.
    -Peter
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Blown engine not providing enough power to spin mgs to charge a hungry battery.
    strawbrad likes this.
  3. strawbrad
    953
    1,007
    On four Prius I have seen a broken piston skirt cause these issues. As Edthefox said it's the engine that can't make the power to move the car and charge the battery.
    First things to check would be to clean the MAF sensor and remove and inspect the spark plugs.
    After eliminating the easy stuff removing the oil pan to inspect for engine chunks would confirm a blown engine.
    I'm in MN. Feel free to call if you need help.
    Raytheeagle likes this.
  4. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    Definitely do the normal tune-up stuff. New spark plugs clean the MAF, air filter.
    If you get a minor misfire in these engines they make a hell of a racket. Especially with a really bad miss.
    I think it's the uneven firing of the gasoline engine creating a bunch of back and forth gear lashing inside the transaxle definitely sounds like a rod knock. Something easy to try.
    GrayRaceCat likes this.
  5. snowboarder
    Eden Prairie, MN
    Thanks for the input.
    I was unfortunately thinking catastrophic engine issues. But, taking a look at the plugs and the sensors will be an easy start.
    Dropping the oil pan may be a bit messy but not too difficult.
    I'll be looking into it this 3 day weekend.
  6. snowboarder
    Eden Prairie, MN
    I put in plugs and cleaned up the sensors. It helped a little.
    Finally family and weather cooperated this morning and I dropped the oil pan.
    Yup, piston skirt.... Dang. :(
    I'm handy but old enough these days not wanting to do an engine swap myself.
    I have seen some engines available locally for less than $2k with less than 150k miles.
    What is the going rate on an engine swap these days?
    (Minnepolis, MN)
    Thanks,
    -Peter
  7. bisco
    52,008
    that sounds very high for an old engine
  8. strawbrad
    953
    1,007
    For less than that you should be able to buy and have installed a good engine. Use car-part dot com to find engines. LKQ Viking in Northfield has a 123K mile engine for $480. Randy's Auto Salvage Eau-Claire WI has a 133K engine and transmission for $300. It's actually less work to replace the engine and tranny together.
    I hear you on being old enough to not want to replace the engine even though you have the ability to do so. Last year I paid $800 to have the engine swap done.
    You will find that many repair shops don't want to replace engines. I think they can make better money doing more smaller repairs. If you want I check check with a couple of shops that are not scared off by hybrids.
    #8 strawbrad, Jul 21, 2020
  9. seeker311
    seeker311 Junior Member
    43
    17
    Austin, TX
    Same issue as Peter. Dropped oil pan 2 weeks ago. Found piston skirt. Still driving, but this morning I saw the hybrid battery not charging and no power. Ice revs, but car does not move like it should. Gonna buy a Gen 3 with blown motor and swap a 4th gen into it. Thanks for the info everyone.
  10. Mendel Leisk
    41,536
