Engine Lights came out
Discussion in 'Newbie Forum' started by Triparadox, Mar 12, 2019.
  1. Triparadox
    Triparadox Active Member
    201
    108
    I just purchased a car not very long ago (within one month) and it showed me an engine light indicator. Once plugged with OBD2, it appeared that there were multiple misfiring from Cyl. 1 and Cyl. 2. I swapped both spark plug and ignition coil as follow:
    1 to 4
    2 to 3
    I resetted the indicator. Today it came back again, still with Cyl. 1 and Cyl. 2 with an additional P0103 (MAF). Can anyone give me some suggestion???
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    How many miles on it? Could be lots of things mileage related.
  3. Triparadox
    201
    108
    192,000 I believe
    52,351
    What car?
    What age?
    Start by cleaning the maf sensor
  5. Triparadox
    201
    108
    2010 Prius Trim III.
    Bought when it has 192,000 miles already.
    Haven't travelled more than 200 miles I believe
  6. bisco
    52,351
    is it something you can detect while driving, or just the codes?
  7. Triparadox
    201
    108
    The codes.. And sometimes rattling when starting up the engine.
  8. bisco
    52,351
    Have you cleaned the maf sensor yet?
  9. Triparadox
    201
    108
    I have just cleaned the MAF sensor last night and resetted the code. But I'm planning on cleaning the EGR anyway since the only time I've got is weekend..
  10. bisco
    52,351
    good idea (y) see the nutzaboutbolts video and do the whole circuit
  11. Triparadox
    201
    108
    Second thought: it's too hard to clean EGR. Guess gonna just try to clean the Intake Manifold..
  12. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    It isn’t that bad;).
    Where in California are you located:whistle:?
    If you only do one, you haven’t gotten the whole circuit and the problem remains:cool:.
    Good luck and keep us posted (y).
  13. Triparadox
    201
    108
    I'm around Tracy... And maybe I'm gonna do it tomorrow... I've done the Intake Manifold.. Gonna check the fuel injector as well.. Other than those three, I have no idea what else may be broken (don't tell me head gasket inside the engine.. Not gonna do that)
    Raytheeagle likes this.
  14. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    If you need Techstream to read any codes, @gta_ is local to you and has a copy:).
    Any questions as you progress through the job, keep us posted (y).
  15. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    It looks intimidating but it’s not that bad once the lower rear nut is off the EGR cooler. You should give it a go, the life of your head gasket/engine could very well depend on it.
  16. Triparadox
    201
    108
    I'm thinking to clean only the EGR valve. Going down to the cooler is too much work and this is literally the first time I've ever do any kind of work to a car. This is my first car.
  17. Triparadox
    201
    108
    I do have the OBDII scanner for around $20. I think that, for now, is more than enough.
  18. Triparadox
    201
    108
    Update: I just did the whole thing I possibly can:
    (i) cleaning MAF and the sensor, (ii) EGR pipe, (iii) intake manifold—puddle of goo, yuck. Resetted the error light and so far, from P0300 to P0303 and P0103 now has decreased to P0301 only so far. Hopefully it'll stay the same. For this one, I don't know what's the problem:
    Ignition coil, spark plug, intake manifold cannot be the problem I believe..
  19. Mendel Leisk
    41,865
    The EGR cooler and valve are really one item, comes out together. Read this thread all the way through:
    EGR & Intake Manifold Clean Results | PriusChat
    A couple of points regarding coolant:
    1. You do not need to disconnect any coolant lines to do the intake manifold. You can remove the throttle body with hoses attached, and just tie it off to the side.
    2. With the EGR valve/cooler removal: if you drain a couple of quarts from the radiator into a clean container, the coolant level drops completely below the egr valve/cooler (apart from a little, trapped at back corner of cooler, which you can carefully tip out, and to your previous drain). When everything is reasembled, pour the drained coolant back into the reservoir. The level will be a little high, but will settle with a drive or two.
    How badly clogged was that pipe? That'll give you clue as to what the rest of EGR system condition.
    Also, thoroughly clean the intake manifold, especially the little EGR tubes, one per port.
    And, watch all the relevant @NutzAboutBolts videos. There's a thread pinned at top of 3rd gen maintenance forum, with all the videos.
    Does the engine coolant level hold pretty steady. If it's always dropping, could be head gasket failing. Leak down test would help diagnose.
    NutzAboutBolts likes this.
  20. padroo
    padroo Senior Member
    2,763
    2,252
    It could be some clogged fuel injectors, try putting some heavy duty fuel injector cleaner in the gas tank. Misfires can be caused in two ways, lack of spark and lack of fuel. It sounds like you addressed the spark problem.
