engine maintenance light on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by suprat04r, Jan 24, 2012.
  1. suprat04r
    suprat04r Junior Member
    85
    las vegas
    hi i just bought my 2007 prius about a month ago. now the check engine light is on... can i go to 7/11 to get the code checked? also i need to smog the car soon.. so hopefully the code isn't that big of a problem. the car runs great still.. averages around 50 mpg so far..
  2. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    The light (maintenance light) means the car thinks it's time for an oil change. Instructions to turn it off are in the owners manual.
    If it's actually the CEL instead of the maintenance light, any good shop with an OBD reader can pull the codes...post them here.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Adding to the above, the maintenance light is just a 5,000 mile counter. You reset it, and 5,000 miles later it turns on to remind you about oil changes.
    Tom
