Engine maintenance required message
Discussion in 'Prime Main Forum (2017-2022)' started by KCWhitney, Sep 12, 2020.
  1. KCWhitney
    KCWhitney Member
    91
    102
    Connecticut
    I am getting the "Engine Maintenance Required" pop-up message. Is this a sign a problem has been detected, just a nag to go pay Toyota for a check up. I have about 42K on it, and just had my last check up in April. Is every six months a reasonable interval to for regular check-ups? It seems like a its a short time.
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    It means you've driven 5,000 miles since the light was last reset. See your Warranty and Maintenance guide to find out what maintenance is due.
    40,000 is pretty basic.
    45,000 has more stuff to check and it's about where I am.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    AND 5000 miles is the interval recommended for tire rotation. No other service is due at that time.
    I usually just stare at that light for about 2000 more miles and then get all of the service done at the same time (oil change mostly).
  4. Trollbait
    11,514
    It's a nag for scheduled maintenance. Nothing more than a 5000 mile countdown clock.
    It will come on, and then eventually turn during the trip when it hits 500 miles before.
  5. ChapmanF
    15,485
    Be sure to look at the Warranty and Maintenance Guide to see what is due at each of those 5,000 mile intervals. You'll notice that it describes several different categories of driving conditions. You're on the honor system to decide which category your driving falls in. My category, for example, has oil and filter changes due every 5,000.
    jerrymildred likes this.
  6. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    The maintenance warning is strictly on miles driven since the last reset. If you go with 6mo/5k whichever comes first schedule Toyota recommends, sometimes warning can come very quickly, if you drive a lot.
    With COVID-19 restriction, I am driving very little, my first service was due last month for the 6mo check-up, but ODO is reading only 1900miles. I will not see the maintenance warning for at least another 8 mo at this rate.
