Engine Mileage vs Battery Mileage
Discussion in 'Prime Accessories and Modifications' started by jan1of1, Apr 28, 2022.
  1. jan1of1
    jan1of1 New Member
    Ohio
    2020 Prius Prime
    Did Toyota provide a mechanism to determine how many miles on the Prius Prime was accomplished using the engine vs the battery? Example: Car has 20,000 miles on the odometer, but I use the car mostly around town - using battery power. So my car, using the 20,000 mile example, may have 19,000 miles using the battery and only 1,000 using the engine. Is there some software in the car that can tell me that? Thanks in advance.
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    One of the screens shows the percentage of miles that are EV. By "EV" is simply means that the ICE was not running regardless of whether you put it in EV mode or if the ICE just shut off. So, for example, if you have 10,000 total miles on the car and that screen says 60% when you have the odometer selected on your trip meter, then you drove 6,000 miles with the ICE off. It will give the percentage for trip A, trip B, and the current trip also.
    Salamander_King likes this.
  3. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    It is on the Drive Monitor corresponding to ODO . If you have not reset the data then the EV ratio is for the entire ODO mileage. Screenshot_20220429-082743.jpeg
    Chris HV, mc357 and jerrymildred like this.
  4. jan1of1
    jan1of1 New Member
    Ohio
    2020 Prius Prime
    Thanks for the help!
  5. PaulDM
    PaulDM Active Member
    616
    318
    UK
    2022 Prius
    Excel
    Same on a non prime.
    jerrymildred likes this.
  6. mc357
    mc357 Junior Member
    17
    ct
    I have noticed the hour meter is not accurate. It must reset every so many hours.
    Does the EV percent also reset with the hour meter?
  7. Salamander_King
    10,970
    8,853
    New England
    Nither the hour meter nor the EV ratio reset by itself unless you reset it. The hour meter cycles after reaching 99:59 and then back to 00:00. It can not display larger than 99:59. So, for a very long period monitored under ODO, the hour meter is useless.
