Engine moves with transmission shift?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Untimely Mechanic, Oct 11, 2024.
Tags:
  1. Untimely Mechanic
    Untimely Mechanic New Member
    St. Paul, MN
    Greetings:
    The attached videos are of my 2007. The behavior occurs when shifting from Park to Reverse or Drive, and I'm wondering if it's normal or if it means something is loose!
    Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    11,995
    2,119
    Durham NC
    Yep that's engine torque flexing mountst doesn't seem too too bad.
  3. Mendel Leisk
    40,457
    Something to keep in mind, if you’re doing something like mounting an oil catch can.
  4. Has Raf
    Has Raf Member
    180
    42
    Stoke-on-Trent, England
    IMG_2779.jpeg Worn engine mounts? Check lower engine mount underneath.
