Engine noise while accelerating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AceWorthy, Nov 10, 2014.
  1. AceWorthy
    AceWorthy New Member
    St. Catharines, Ontario
    Hello,
    My 2010 Prius has been making an odd noisse intermittantly while accelerating. I haven't been able to reporduce it for the mechanics (of course). The best description I have for the noise is this. It sounds like the click/rattle sound a car makes when it is stalling. Just sped up. This can happen at any time I accelerate (even at highway speeds) but it usually happens just after I start moving from a stop. When it occurs it feels like there is a drop in engine power and I either have to take my foot off the accelerator, or push down harder and power through.
    Has anyone else experienced this?
    Thanks
  2. JC91006
    16,673
    8,518
    do you have enough oil in the engine?
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Could be anything or nothing.
    A few more details about your car might help work this out; do you have 10,000 miles or 280,000 miles on the car, for example? What do you use the car for? Is it a lightly used second car or a taxi?
    Could be pinking due to wrong or contaminated fuel. But it could be anything without knowing more. You gotta help us to help you (y)
  4. mrbigh
    3,686
    699
    Long Island, NY
    Dirty throttle body for the lack of power?
    #4 mrbigh, Nov 11, 2014
  5. AceWorthy
    - My Prius has about 250000km on it (not sure what that is in miles) and I use it to drive to work (which is an hour away by highway).
    - Due to the mileage I do it is in for service about every other month so the oil is good. I also visually checked and the levels are good.
    - I always use the proper rated fuel at busy stations so the fuel should be good.
    Another thing I forgot to mention; the issue seems to occur more often on cool, damp days.
  6. bisco
    51,154
    did they check it for trouble codes? maybe an injector service? have they cleaned the throttle body?
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Yeah it could be anything at that mileage. Get the dealers to check codes as that will give a good indication of what's wrong. Could be a simple misfire due to a failing coil pack or spark plug or throttle body sensor. Maybe even a gummed up EGR valve. All these issues should show up as a code.
    If you wanted instead, you could try some fuel system cleaner or check when your spark plugs were last changed etc, but you're probably best seeing your local friendly Toyota dealer.
  8. dame3780
    dame3780 Member
    59
    53
    SoCal
    I've been having the same issue for at least 15k miles. Did you ever get it figured out? Mine happens after letting off the gas and slightly accelerating between 15-30mph. Every time. Rattle sounds from the passenger/glove box area. It's annoying and I'd like to see what you may have done to remedy the problem. Thanks
  9. dame3780
    dame3780 Member
    59
    53
    SoCal
    Update: My rattle was diagnosed from Toyota as a loose strut bracket. It is still at the dealer. Will give an update once I get an opportunity to drive it. Working with ext. warranty so it's taking some time.
  10. ilovegirls
    ilovegirls Member
    177
    San Diego
    What's a strut bracket? I have a weird rattle going over bumpy roads.
  11. dame3780
    dame3780 Member
    59
    53
    SoCal
    I believe it to be the top mount holding the strut in place. Toyota is also replacing the right lower control arm. Still waiting for repairs to be completed.
