Engine Noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jane Doe, Jan 28, 2019.
Tags:
  1. Jane Doe
    Jane Doe New Member
    Amherst
    Hi all!
    So recently my Prius has started to make extra noise when I accelerate. It sounds like a fast "putting" noise or the noise that cards make when you shuffle them. It's not exactly a ticking noise, more like a fast "farting" noise. (I know that is a weird description). I have had the noise before, but it went away. This time it hasn't. I only hear the noise when I accelerate. Should I be concerned about this noise? This noise makes me hesitant to accelerate at the speed that I need to
    Any help would be great. Thanks!
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    How many miles on the vehicle, and where is the noise coming from?
  3. Jane Doe
    Jane Doe New Member
    Amherst
    it has 174,400 miles on it about. The sound seems like it is coming from the front of the vehicle. I am guessing it is related to the engine/acceleration because the only time I hear it is when I accelerate.
    Thanks!
    49,416
    hole in the manifold/exhaust?
  5. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Located a muffler shop that offers 'free inspections' and see if maybe they can find the problem, or create a new one for repair o_O
  6. Jane Doe
    Jane Doe New Member
    Amherst
    Should I be concerned about driving over 50 miles on it till I get it fixed? Like how much of an emergency do you think the problem is?
    Thanks for the help!
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Low engine oil and engine is complaining? Go on you tube and search
    prius inspection
    it will show you how to make the engine run continuous. Then with engine running continuously open the hood and listen around for bad noises. Probably a bad water pump belt or water pump or low on engine oil. Or you ran the engine out of engine oil once and damaged the motor and you have bad main bearing. See alot of those here. Ever run the engine oil so low the check engine light came on or the red triangle of death?
  8. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Can't say if that would be wise or not, as we don't know what the actual problem is beyond a noise coming from the front during acceleration.
    As @edthefox5 mentioned above, have you checked the engine oil lately?
    Raytheeagle and edthefox5 like this.
  9. ScottHz
    ScottHz Junior Member
    Kannapolis
  10. mr_guy_mann
    mr_guy_mann Senior Member
    3,447
    1,496
    NJ-USA
    Why are you replying to a post from 4 1/2 years ago? The OP has been on the forum since that last post.
