Engine noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joebif, May 27, 2011.
  1. joebif
    joebif New Member
    On my 2010 Prius ll when the engine kicks in, is it normal for the engine to sound noisy, almost like a diesel. It's embarrassing because the car is noted for bring quiet. Is it not? It was like that when I got it, and I took it back and they checked it out, but apparently they thought it was ok. I'm thinking of taking it back again. Just a little over 4000 miles on it. I am troubled by this, can someone help me out!
    Thanks in advance,
    Joe B
  2. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    all priuses are noisy when the ICE kicks in...completely normal
  3. joebif
    joebif New Member
    What does ICE mean. For whater reason I don't know though I have seen that mentioned before.
    Thank You!
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Internal Combustion Engine.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The engine is usually a little noisy and rough when it is cold. It should be much smoother and quieter when fully warmed up.
  6. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
  7. kklin
    kklin New Member
    CA
    my 1-month old Prius also has some "strange noise". A loud thud noise will sound when after I put the car in "R". After that "noise", then I can back out of my garage. Is this normal? Thanks
  8. grharman
    grharman Junior Member
    23
    arkansas
    I have a 2011 III, and I have no ICE noises, hot or cold, nor do I hear anything when going from D to R or vice/versa. Mine is completely silent. I know there was some discussion on the VVTi issue, but not sure if that is what you are hearing.
  9. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Hi Joe,
    A distinct possibility, especially if this comes near the start of the trip, is that in the first minute or so of driving, when your car drives essentially on all battery power (you hear the engine, but it's not driving, just warming stuff up), it lowers your hybrid battery's state of charge to a point where, after warming up for that minute or so, the engine works extra hard to recharge the battery. It will rev more and the acceleration will not be as smooth and easy compared to a time when your battery is relatively well charged.
    You can read more about someone else's experiences with a lot revving on the highway, and a possible way to help it out or alleviate the problem:
    http://priuschat.com/forums/gen-ii-...3304-odd-experience-higher-speed-tonight.html
