Engine noisy when tank is low(!?!!?!)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Jun 7, 2019.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    hey all. So I’ve seen some fuel filter/fuel pump threads and the consensus for North America cars is “no user serviceable parts inside”. Hmm ok. So anyway I’ve noticed that when my ‘06 with 217k miles, recently purchased, becomes lower in fuel the gas engine gets louder and louder. Not lawnmower loud but it is worrisome. Today I noticed that as soon as I fill the tank up it becomes nearly silent. It’s not a subtle difference it’s night and day. Keep in mind the change starts at the first start up while it’s still burning fuel from the previous fill up. Strictly tier 1 87 octane chevron gas. Same station, same pump. It’s like something about the extra pressure from a full tank makes the engine run like showroom fresh? Any ideas?
    SFO likes this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    You could try checking the fuel pressure with a full and near empty tank and see if there is a difference. That would be my first step. And yes if your pump is shot or fuel filter inside the tank is clogged you need to buy a new fuel tank. 77001-47090. Tracy Toyota internet price is currently 452.41 new. Or you could get a used one.
    #2 Skibob, Jun 7, 2019
    SFO likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    How LOW do you let it GO ??
    The extra noise could be coming from a failing fuel pump......which you don't hear as long as it is immersed in fuel.
  4. Ianmeister
    316
    319
    Meridian Idaho
    To the first ping of low fuel then 2 minutes to the closest station. It took exactly 9 gallons.
    I’ll try the pressure thing.
  5. Skibob
    2,912
    1,505
    Northern California
    Do you mean the first dot? 1 dot lit? That’s pretty low, Prius gas gages are not known for their high accuracy. 9 gallons is a lot but I can’t say if you were about out of gas or not. You were pretty close though. Does it make the sound when you have 2 dots of fuel left?
  6. Ianmeister
    316
    319
    Meridian Idaho
    Yes. Even 3
  7. Ianmeister
    316
    319
    Meridian Idaho
    I think I’ll just refill at 2 dots need it or not
  8. Skibob
    2,912
    1,505
    Northern California
    Fuel pressure check then.
  9. Ianmeister
    316
    319
    Meridian Idaho
    Where’s the Schroeder?
  10. Skibob
    2,912
    1,505
    Northern California
    I don’t think there is a schrader valve to check the fuel pressure. You have to tap in. I’m sure someone here will post the procedure.
    @SFO
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I doubt its got anything to do with fuel level whats probably happening is the hybrid battery may be tdying and when that happens only thing left to power the car is the tiny little under powered engine. The engine will be screaming to go anywhere. I suspect the hybrid battery is bad because that's like the #1 reason people dump there used G2.
    Next time it starts doing it monitor the battery level on the mfd. I bet the battery is in purple which is basically empty.
    Or just watch the battery level....if it goes from blue to purple real fast and will not go back into blue within 2 miles its time for a new battery or a rebuild.
  12. Skibob
    2,912
    1,505
    Northern California
    Why would you think it’s the battery when the fuel gets lower? If anything it would be opposite. The car gets lighter as the gas tank empty’s
  13. Ianmeister
    316
    319
    Meridian Idaho
    Agree with Skibob. Today for example the car was one battery bar short of 100% green, fuel gauge was blinking one spot when I pulled into the gas station. Filled up. On restart I wasn’t sure if the ice was running it was so quiet. For reference the only times I got the battery down to purple on a looooong high speed uphill run it bounced back to light blue in under 5 minutes. I really don’t think it’s Hybrid battery related.
  14. Skibob
    2,912
    1,505
    Northern California
    You really need to check your fuel pressure. I guess best way would be to check it at home when the gas tank was almost empty, then throw like 2 five gallon gas cans in and see what the pressure reading is then. Plus I was not kidding about the gas gage. Plenty of posters here have run out of gas on 2 dots. The gas gage on a gen 2 prius is more of guess than anything else. It’s the stupid fuel cell. Even NASCAR has troubles with it. And they get millions to work it out.
    #14 Skibob, Jun 8, 2019
    edthefox5 likes this.
  15. Ianmeister
    316
    319
    Meridian Idaho
    Ok. 3 dots fill up from now on :)
  16. frodoz737
    frodoz737 Top Wrench
    4,722
    2,517
    33
    If you ran diesel, I'd say you were sucking water from the bottom of the tank.
  17. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Is the gas station at the top of a hill? I mean I don't think it's that simple, but technically that would explain things.
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    Regardless of the noise you are trying to identify......THIS is a BAD habit and you need to work on changing it.
    Someday it will bite you in the butt and the engine will go completely quiet......when it runs out of gas. :eek:
  19. Ianmeister
    316
    319
    Meridian Idaho
    No it was on level ground
  20. broski
    broski Junior Member
    44
    23
    MN
    @Ianmeister my car does this as well..I am fairly sure what is actually happening is that there is an exhaust leak that is less apparent when there is more weight in the back (i.e. full tank). Did you solve your problem?
