engine number location?
Discussion in 'Gen 2 Prius Technical Discussion' started by johngeeman, Apr 3, 2008.
  1. johngeeman
    johngeeman New Member
    australia
    I cannot find whereabouts on the engine is the engine number located???
    I have a NHW20R. Any ideas plz???
  2. patsparks
    10,664
    567
    Adelaide South Australia
    The handbook shows you where it is. Try the face of the engine facing forward on the trasmission end of the engine block right under the inlet manifold.
  3. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    You mean the engine model?? 1nz-fxe is the engine used in all prius up to this point. You can find that on the emissions sticker under the hood.
  4. Patrick Wong
    18,200
    6,471
    See attached .pdf file.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    wow, whatever that "win2pdf" garbage was that generated that,
    it totally mangles the rendering and the images aren't even there.
    _H*
  6. lr08
    lr08 Junior Member
    Hey, thanks for the pdf. A great help! I could read it easily, no problems.
  7. ChapmanF
    15,410
    The engine serial is stamped into the block just below where the 1NZ FXE is cast into it. It's hard to read with everything installed (on my NHW11 anyway). So is the transmission serial number, which is nearby. The manual does show where the numbers are supposed to be, but actually reading them took me at least half an hour of unclipping hose and wire harness brackets, shoving stuff out of the way, and finally jockeying a digital camera down into positions my face wouldn't reach (after first jockeying a flex-shaft Dremel wire brush down there to clean up the numbers enough to be legible).
    -Chap
