Engine Oil Pump
Discussion in 'Gen 4 Prius Technical Discussion' started by Tansu K, Apr 14, 2022.
  1. Tansu K
    Tansu K Junior Member
    Turkey
    2020 Prius
    hello everyone. I am writing you from turkey. I have a 2020 model corolla hybrid car. It is produced in Turkey. 4th generation hybrid. P610 with transaxle. It has an 1800 cc 2zr-fxe engine. I wonder something. Is the engine oil pump electric?
    Partsouq photo:
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,585
    NJ-USA
    No, the oil pump is mechanically driven. It has a small chain from the crankshaft to sprocket on the pump.
    Tansu K likes this.
  3. Tansu K
    Turkey
    2020 Prius
    contunually isn't stopping and starting very harmful for the engine?
    49,521
    no, it was designed to do that for hundreds of thousands of kilometers
    Tansu K likes this.
  5. Tansu K
    Turkey
    2020 Prius
    I would have preferred the oil pump to be electric.
    Istanbul's traffic is very busy. All roads are red on google maps. but my fuel consumption is 4.5 lt/100km. other petrol cars at least 10 lt/100km. diesel cars fuel consumption 7-8 lt/100km
  6. dacoobob
    dacoobob Member
    83
    45
    Kansas City, MO
    Four Touring
    an electrically-driven pump would be less efficient: converting the mechanical, rotational energy of the engine crankshaft into electricity, then converting that electricity BACK into the mechanical rotation of a pump would involve more losses than mechanically linking the pump to the crankshaft.
  7. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Toyota has it figured out. To make the Corolla hybrid they used the same technology from the Prius. For the most part the Prius has been very reliable.
    dacoobob likes this.
  8. rjparker
    rjparker Tu Humilde Sirviente
    8,001
    4,741
    Texas Hill Country
    In older engine designs with conventional oil, frequent start stop would be an issue. Better tolerances in Toyota hybrids and especially synthetic oil helps.
    Toyota made their water pumps electric as a method to combat thermal cycling which is a bigger issue. They also went to special cylinder insulators on gen4 for the same reasons.
    #8 rjparker, Apr 25, 2022
    dacoobob and 2010moneypit? like this.
  9. mr_guy_mann
    3,483
    1,585
    NJ-USA
    An electric oil pump would have to have a fairly large motor to supply maximum pressure and volume at high engine RPM. That increases cost and puts more load on the 12V electric system.
    There must not be enough gain vs cost to using electric oil pump - I have never heard of any car with this.
