Engine oil recommendation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fwbrc51, Jun 25, 2010.
  1. fwbrc51
    fwbrc51 Junior Member
    61
    Fort Walton Beach / NW Florida
    hey folks. I bought a used 08 prius a few months ago with just under 13k miles. i've driven somewhere over 4k miles since i've owned it and now the maintenance light is on. I'm assuming this car has a mileage counter for oil changing purposes.
    I've already bought 10 oem filters with drain plug washers ($48.50), but i still have no idea what oil to put in this car. I need to remedy this sometime this weekend.
    what's your recommendation?
  2. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I've used Mobil 1 for years and think it's great. The engine seems to run more smoothly with it compared to dino oil, but that's probably my imagination.
  3. roverguy78
    roverguy78 Elite Lurking Member
    118
    24
    San Antonio, Texas
    I use Mobil 1 5w30 synthetic. You can get a 5 quart jug for around $22. I recommend using only 3.5 quarts. It will still be close to the high mark, but not over. 4 quarts is a bit too much.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The Toyota oil recommendation is on the oil dipstick cover.
  5. fwbrc51
    61
    I was looking for brand and type; conventional or synthetic.
    I automatically assume the type 5w, 10w, etc is at the fill location.
  6. Patrick Wong
    18,200
    6,474
    3.5 US quarts of 5W-30 synthetic oil; whatever name brand is on sale at Walmart at the time you decide to buy oil. When on sale a 5 gallon jug of synthetic oil sells for ~$22.
  7. richard schumacher
    7,663
    1,038
    United States
    Then go buy an owner's manual. It's full of Prius-specific stuff that you need to know. See also the maintenance schedule at
    Toyota Parts and Service
  8. spitinuri
    spitinuri Member
    317
    I use Mobil 1 OW-20 synthetic. I believe I get about 2-3 more mpg vs dino. In Japan OW-20 is recommended for the 04-09 Prius. The reason they didn't use that standard in the US was the availability of product.
    Have fun with your car.
  9. Patrick Wong
    18,200
    6,474
    I wonder if another reason might be hotter summer temps in portions of the US: NV and AZ deserts, Death Valley in CA, etc.
    A couple of years ago I tried Toyota 0W-20 in my 2004 while still in southern CA, during the winter. That seemed to improve mpg the same extent that you had noticed. However the engine started to consume oil (at the rate of 1 quart after 5K miles) and this has continued (although at a lesser rate, 0.5 qt after 5K miles) when I switched back to 5W-30 synthetic.
    So I advise caution to 2G owners thinking about switching to 0W-20, who live in relatively warm climates and whose vehicles have logged more than 50K miles.
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Agreed. Although I ran my '04 Prius most of its life on Mobil 1 0W-20 with ZERO oil consumption, our summer temps rarely exceed +35 C. OTOH the winter temps can hit -40 or a bit colder
    Thing is, when I compared Mobil 1 0W-30 to Mobil 1 0W-20, there was NO difference in summer fuel economy that I could determine. There was a minor improvement in winter fuel economy
    I had good used oil analysis results, so kept using the 0W-20.
    My FJ was another matter. I am sitting on all this Mobil 1 0W-20, and discover the 4 litre V6 is approved for xW-20. Tried the 0W-20 as a "winter" oil and had horrible used oil analysis results.
    YMMV in more ways than one
  11. sub3marathonman
    sub3marathonman Active Member
    557
    75
    And here is something surprising about Mobil1 oils. If you think the 10W-30 would be better for hot summer driving, which would be logical, you would be wrong. The cSt @ 100°C for the 10W-30 is 10.0, while the cSt @ 100°C for the 5W-30 is 11.3. The cSt @ 100° C range for 30 weight oil is 9.30 to 12.49.
  12. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Jayman, are you saying that you got slightly better winter FE with the 0W30? I would have thought the thinner oil (0W20) would give better FE in very cold conditions. ???
  13. jreed
    jreed Member
    84
    71
    North Carolina
    I got to this thread a little late, but wanted to add that I've been using regular Pennzoil 5W30 in a 2006 with 98K miles and it seems to be OK. I've been buying the big container (5 quart) at Wallmart for about $12 or $13 and putting in 3 quarts, which brings the level to halfway. The oil level hasn't been dropping in between oil changes every 5K miles. :)
  14. jayman
    13,439
    640
    Winnipeg Manitoba
    No, that was poorly worded on my part
    In very cold winter temps, eg <-25 C and especially -40 C, I had a slight improvement in fuel economy running Mobil 1 0W-20
    Otherwise, there was no difference between Mobil 1 0W-30 and Mobil 1 0W-20
  15. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    This site has access to owner's manual etc. ;)
    Toyota Owners Online | Official Toyota Owners Website
  16. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    0W30 Mobil 1 and the dealer put it in without a question. Cold climates maybe 0W20.
  17. fwbrc51
    61
    Well thanks to everyone for their answer to my question and their 2 cents as well.
    I changed the oil with 5w-30 mobil 1 and a stock oil toyota filter. the oil was on sale at $21.00 for 5 quarts. i put in 3.5 quarts.
    I must say, changing the oil was very messy with removing the filter compared to my 2.2 95 S-10. I also had lots of fun with a makeshift ramp to get the front higher so i could work under the car. I'll be looking for a ramp extender for my existing metal ramp and also a 2nd oil catch pan to use for the oil filter and keep my existing one under the oil pan drain to let all the old oil drip out. I was also surprised that my motorcycle oil filter socket was a perfect fit for the prius filter size.
  18. fwbrc51
    61
    I live in nw florida which stays fairly warm and rarely cold long enough so i'll stick with the recommended 5w-30.
  19. fwbrc51
    61
    i think next time i'll drill a small hole in the bottom of the old filter before i remove it so it's a cleaner removal.
  20. jayman
    13,439
    640
    Winnipeg Manitoba
    I used to just cut an old 2 liter pop bottle in half. Loosened the filter, then slipped the old pop bottle over top and continued to loosen it up. Any spillage went into the pop bottle
    My FJ, the filter is right on top of the motor, and is upside down. There is a catch basin under the filter, and the catch basin has a small tit at the lowest point
    So I use an empty 1 liter pop bottle - shove the bottle up into the tit, loosen the filter, perhaps get 200 ml into the pop bottle, and not spill one drop anywhere
    At first I was leery of the FJ oil filter location. Now I love it, very easy oil changes. Naturally the 2010's went to the dreaded cartridge oil filter
