Engine Oil
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, Nov 4, 2019.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    Hello again, this time I was wondering if it is a necessity that the engine oil tank should be filled up completely?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    What is the engine oil tank exactly?
    Do you mean the engine oil, inside of the engine?
    This was already hashed out in another one of your threads a couple of years ago : Engine oil level | PriusChat
    edthefox5, Raytheeagle and bisco like this.
    52,373
    i fill it til it starts going out, then screw the cap on quickly
    edthefox5 and m.wynn like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,044
    5,299
    Pacific Northwest, USA
    There's no such thing as an engine oil tank... There is oil in the engine crankcase and there is transmission fluid in the transaxle and maybe you just asked the question wrong, but... There's so much wrong with this question in so many ways, maybe this is just a spam robot making the comment?
  5. Georgios
    Georgios Member
    126
    85
    Chicago
    :LOL: made my day
    I have seen this happened but another person caught it on time before the guy started driving
    Now seriously, GeorgeMW, you do not fill this up all the way like a windshield washer fluid for example. If you change oil yourself l, which i doubt, you put 3.6-3.8 qts
    If your oil level is on minimum or under minimum immediately add until it reaches the top dot mark . Ideally just a little under it according to some geeks here. From bottom mark to top mark is 1qt i think.
    Check your oil levek when car has been off for like atleast 30 mins. If it burns oil which is normal check it every day and you can figure the rate that the oil dissapears. Mine burns like a qt every oil change 4k miles. So i check it once a week. If yours burns like a crazy atleast you will know. Because someone could see the oil is under the bottom mark but has done lets say 5k miles and thinking the engine is oil guzzler.
    Good luck
    edthefox5 likes this.
  6. PriusCamper
    13,044
    5,299
    Perhaps you need to let OP know what a dipstick is and how it works?
  7. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Here's how you do it...
  8. bisco
    52,373
    curious way of posting threads
