Engine over temp light came on
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by RiverRat, Nov 9, 2012.
  1. RiverRat
    RiverRat Junior Member
    24
    Huntington Beach CA
    I ran about 2 miles on EV then switched to HV 1/2 mile before getting on the freeway. After about 3miles red temp light came on:eek: Outside air temp was about 65. I was on a 2 mile long single lane transition so I was unable to get off the freeway. I slowed down to about 60mph from 70mph the light went off. The light was on for about 2min. I got off the freeway and opened the hood. The coolant had over flowed puking coolant all over my clean engine.
    I was able to run EV to dealer to check. :) My guess was a stuck thermostat! Dealer just called me and after calling manufacture to discuss the the error codes and my symptoms, there best guess was a stuck thermostat.
  2. eric smith
    eric smith Junior Member
    44
    DC/Maryland
    Did they replace the thermostat? If it happened once I would bet it can happen again.
  3. RiverRat
    24
    Huntington Beach CA
    Waiting for the Part!
  4. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Does Prius Plug-in have a coolant temp display?
    Prius V doesn't have it but I connected an external one to OBDII port.
  5. RiverRat
    24
    Huntington Beach CA
    No analog type display, just an idiot light. No warning of climbing temp just pow! in your face melt down.
    I also us a blue tooth OBDII with Torque software on my Android
  6. bisco
    52,373
    bummer! no permanent damage tho?
  7. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    The Dealer didn't have a Radiator Thermostat for the PIP ??? WOW.
    By the way, do you Block your Grill?
  8. RiverRat
    24
    Huntington Beach CA
    I Live in Huntington Beach, Ca. So I think its "freezing" and reach for the seat heaters0 when the Temp dips below 65. But to answer your question, I don't block the grill. The day it over heated was a cold day of 68:)
    lensovet likes this.
