Engine races when accelerateor is released
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jaytee, Jun 18, 2021.
  1. jaytee
    jaytee Junior Member
    Tucson
    In very hot weather (over 100 degrees), when I decelerate my engine is slow to decelerate.
    It races like my accelerateor is stuck, but slowly comes to idle after a few seconds.
    Is this normal or do I need to lubricate the linkage?
  2. ChapmanF
    15,465
    It's very unlikely that you need to lubricate a linkage. The throttle is controlled by an electric motor right there on the throttle body, and there's a sensor there telling the car's computer exactly how open the throttle is, and the computer uses the motor to put it exactly where it wants.
    From your post, I'm not sure exactly why the car's computer is choosing the behavior you're seeing, but it's almost certainly exactly what it's programmed to do.
  3. jaytee
    Tucson
    Thank you.
  4. mjoo
    mjoo Senior Member
    1,109
    1,312
    Michigan
    I've seen this when there's a hybrid battery code. Probably because the ECU is idling the engine.
    Is your hybrid battery fan clogged?
    moto g power ?
  5. SebastianB
    SebastianB New Member
    2015 Prius c
    i have had the same problem,at the dealership they said that the engine is charging the EV battery and it's normal, after the dealership visit it stopped,them my EV battery had to be reolaced.....
