Engine rattle and U0100 error
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Pavelea, Jun 28, 2019.
  1. Daniel Pavelea
    Daniel Pavelea New Member
    Romania
    Hello
    First i am new to this so sorry if i posted wrong.
    I have recently changed the spark plugs on a 2012 Toyota prius shortly after i got the Check hybrid system and the engine won't start .
    Plus the relay from the picture started buzzing and got the U0100 error from the picture.
    But if i keep the computer conected to the car it doesn't buzz anymore and after i reset the error the car will start ok.
    Do you know what could it be ?
    I will try to change the integration relay from the picture first. IMG_20190627_202253.jpeg received_620248482127104.jpeg
    Tomass 2 likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Check all connections
    51,144
    welcome!
    how many miles/km on her?
    #3 bisco, Jun 28, 2019
  4. Daniel Pavelea
    Romania
    Hey
    280000 km
  5. bisco
    51,144
    thanks, do i understand correctly?
    1) you got the check hybrid system
    2) engine wouldn't start (or car wouldn't make 'ready'?)
    3) you changed the spark plugs
    4) relay started buzzing and you got U0100 trouble code at what point in the above sequence?
    5) what computer/software do you have connected to the car?
    6) what function does the integration relay serve?
  6. Daniel Pavelea
    Romania
    Hey
    Fixed it today , the problem was a bad grounding from the engine
    I changed the spark plugs because of the engine rattle and after the relay started buzzing and the erors happened, so 3-1-2-4
    I use a deplhi system and the integration relay from what I understood it replaces multiple traditional relays so it saves space and weight nu doing more than one relay.
    After i disassembled it i found out there are 4 smaller relays in IT.
  7. bisco
    51,144
    well done!(y)
  8. Masood
    Masood New Member
    Pakistan
    Dear
    How you fix the bad grounding from engine
