Engine rattle on startup
Discussion in 'Prius v Main Forum' started by Led, Nov 22, 2023.
  1. Led
    Led Junior Member
    37
    Huntington WV
    So what does the dreaded head gasket startup rattle sound like. My 2012 V just yesterday started to make a, well, it sounds like something hitting something in the engine bay. It only rattles for a second or two and clears up. Any ideas other than head gasket? So far I have noticed NO coolant usage.
    52,386
    there are other misfiring causes, how many miles on her?
  3. Led
    Led Junior Member
    37
    Huntington WV
    177K. No codes and it drives fine. This just started yesterday. Was hoping to get 200k before swapping in a 4th gen engine.
  4. Mendel Leisk
    41,898
    EGR and intake manifold ever cleaned?
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,503
    6,593
    Texas Hill Country
    No coolant loss is normal at first. Misfires caused by plugs, coils or injectors won’t clear up so fast. Borescope inspection is definitive but start thinking about your repair options soon. Since you want to change engines, a hole in the block will only speed up the process.
    Shudder video
    #5 rjparker, Nov 22, 2023
    Tim Jones likes this.
  6. Led
    Led Junior Member
    37
    Huntington WV
    I checked EGR last year when I got it. It was in decent shape but not perfect. I think I’ll just drive it until it pops or sell it. I just today got an 2013 Audi S4 6 speed manual from an old friend.
  7. Led
    Led Junior Member
    37
    Huntington WV
    Just watched the video posted. That’s the noise, just doesn’t last that long. Anyone want an otherwise good condition 2012 for a cheap price? Toyota did the rectifier and brake booster under warranty last year.
  8. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    HG for sure.........................
  9. John March
    John March Junior Member
    28
    Winston Salem NC
    2014 Prius v wagon
    My head gasket leak was barely noticeable in the coolant level at first. It wasn't getting into the oil. Eventually, symptoms got worse and coolant leak was noticeable. Good Luck.
  10. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    I have never hear of coolant in the oil on a Gen 3 HG failure. Just rattle and loss of coolant and of course over heating when bad... but have seen holes in the block, bent rods and deflated pistons if you let it go to long...
    Only car I've ever had with a blown HG and i'm in my late 60's.
    These cars are junk aft6er 150,000 miles.......you lose all gas savings on repairs..... and a very good chance you'll be stranded
