Engine Replacement at 113,000 miles?!?!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by missa7894, Mar 25, 2009.
  1. missa7894
    missa7894 New Member
    Washington, DC
    2003 Prius
    I have a 2003 Prius that we bought used last June. It has 113,000 miles on it. (we've maybe put 5000 miles on it since we've bought it) It was making a clanking noise that increased in frequency when I would accelerate and go away when I was coasting. It died on me so I had it towed to the dealership. They said that I needed to have the short block of the engine replaced ($4500) because the bearing had broken (or were damaged or something like that). We are shocked that it needs to be replaced so soon. We have a 2001 Corolla with 150,000 that seems to be working great and expected the Prius (due to being a Toyota) to be just as good. We are regretting our purchase and are wondering if we should even get a Toyota again. I've tried to research about the Prius engines, but the only info I seem to find is about the battery. Does anyone know about the engine? Is it even worth it to replace it? Thanks.
  2. Tideland Prius
    16,445
    Did you have the engine checked before you bought the car?? It depends on how the previous owner treated it.
    The engine in the Prius is nothing special. It's the same engine used in the Yaris and Echo dating back to 1999 so it's 10 years old.
  3. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    That's exactly what happened to my Taurus.
    I managed to squeeze out 15,000 miles before the clanking turned into a destroyed engine. When the bearing couldn't take the pressure anymore, it broke... causing the piston-rod to snap. You wouldn't believe how horribly loud an engine can get when 5 cylinders are tossing around broken metal from the 6th. Needless to say, that level of damage cannot be repaired. The replacment engine swapped in (after pushing Ford to help pay for it) worked pretty well.
    But that experience combined with the transmission problems I also had was what caused me to seek out something better... precisely how I found Prius.
    Sorry, that probably doesn't help you feel better at all other than not being the only person to experience that.
  4. Patrick Wong
    18,200
    6,493
    I suggest you ask the dealer to install a salvage engine, you should be able to buy a low mileage one for ~$500 plus shipping:
    eBay - prius engine, Parts Accessories - buy and sell on eBay Motors=
    Toyota engines usually are quite robust, I suspect the prior owner did not perform timely oil changes. The noise you heard was probably due to a worn crankshaft bearing.
    Remember that when you buy a used car, sometimes you are buying someone else's problems. Buyer beware...
  5. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    you bought a used car that made a clanking noise? you should have run from that as quickly as possible. how long a car lasts depends largely on how well the owner takes care of it. by the time you bought it, poor maintenance could have done some serious damage.
    dealers generally will not install salvage parts, new only. you'd have to go independent to do that.
    would replacing the engine with a salvage cost more than replacing the car? probably not. but next time you buy a car, please get it inspected by a certified mechanic.
  6. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    Hi Missa, first-time poster with a big problem. Sorry you got a mistreated one. It might appear that you are getting slapped around here a bit, but I wish to agree entirely with Patrick that a salvaged engine is just the ticket.
    Nothing 'hybrid' needs to be massively relocated for this, so any good independent engine shop seems like the way to go.
    This is not a new engine in the Prius, but it is subjected to very kind conditions with all the electrical help in this car. Your experience is one of very few, the others are all catastrophic engine oil loss I think.
    I have no worries about Missa in the future, but would every one else reading this please take good care of the engine oil? Yes, it's that important.
  7. richard schumacher
    7,664
    1,043
    United States
    [another redundant post deleted]
  8. missa7894
    Washington, DC
    2003 Prius
    Thanks for the replies. We are looking into having the engine replaced somewhere else besides the dealership. I just want to point out that it was not clanking when we bought it, but we will be sure to, in the future, have a mechanic look at any car that we are looking to purchase.
  9. Patrick Wong
    18,200
    6,493
    Thanks for the clarification. How many miles did you log before the engine started to make noise?
  10. galaxee
    9,810
    468
    MD
    you sure it had enough/any oil in it?
  11. missa7894
    Washington, DC
    2003 Prius
    The engine seems to have been well maintained..we got records from the dealership that the previous owner went to. He got the oil changed regularly. We had the oil changed when we bought it and again just recently (after 5000 miles, which is how many we've put on it since it was bought). The mechanic said that there was too much oil in it. How does that happen? Did who we took it too put in too much or the wrong type?
  12. galaxee
    9,810
    468
    MD
    you can't damage a bearing with too much oil.
    how much time elapsed between oil change and engine failure?
  13. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    No, in my experience the dealer assholes at Toyota (Albany, GA) will tell you they can't get the new, install the salvaged parts, say you have a year warranty on them, then not back it when it turns out the salvaged parts were bad.
  14. Patrick Wong
    18,200
    6,493
    Hi Shawn,
    Well, I hope you were not charged for new parts, when salvage parts were installed...
  15. missa7894
    Washington, DC
    2003 Prius
    According to my husband..the oil was changed in August (about 3000 miles ago). I think that that was the first time we changed the oil (not in June when we bought it, but apparently the guy we bought it from said he had just changed it). We haven't really driven it that much lately. But a few days before engine failure, I was driving on the highway and it sounded different (like it was having trouble changing gears) and it felt a little sluggish. When they looked at the engine, they did say there was too much oil (i'm not sure how that happens), but that the cause of the bearing failure may be not enough oil. We are kind of confused about the conflicting info. Not too long before the engine failed we put a new battery in it.
  16. Celtic Blue
    2,224
    139
    Midwest
    Technically I was not, but the price was about the same as what new would have been. This was for the Tundra. They are real rip off artists at that dealership. Lied to me half a dozen different ways, and installed faulty parts. Hanging would be too good for them.
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    They should be chopped into little itty bitty pieces and buried ... alive
    Source: Heavy Metal, the movie
    Seriously, if a dealership tried to screw me that badly, it would be dangerous for them. Just ask the nice folks at the GM dealership where I *special ordered* my 2000 GMC Sierra
  18. itndave
    itndave Junior Member
    22
    San Mateo CA
    Hey folks,
    It would appear that over filling of the crankcase would lead to foaming. This severe foaming of the oil (oil aeration, from the crankshaft counter weights whipping the oil like an egg beater) caused a failure similar to oil starvation. One of the single most important reason to never overfill an engine with oil.
  19. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Engine Oil Bible has this to say:
    "What's the worst that could happen? Well the problem with this is that the next time the engine is run, the windage in the crankcase and other pressures generated by the oil pump, etc. place a great strain on the seal on the rear main bearing.
    Eventually, often much sooner than the ordinary man in the street might expect, the rear main bearing seal ruptures, and the engine becomes a 'leaker'. If you've got a manual gearbox, this means one thing: this oil goes right onto the flywheel and the face of the clutch disc. A lubricated clutch is A Bad Thing. If this still goes unnoticed, the front seal is the next to go, and the engine then becomes a 'gusher' (or to be more colourful, it starts pissing oil all over the place). As well as smothering the clutch with oil from the rear, the oil now coming from the front leak will be neatly distributed about the engine bay as it hits the front pulley - often propelling it out as far as the brake discs. At the same time as this Hollywood disaster movie is unfolding outside the engine, things aren't working out any better on the inside. As you can see from the diagram, the correct oil level is really close to the rotating crank. Overfilling will mean the crank dips into the oil and churns it into a froth. Froth is good on certain types of coffee but not good in an engine. The mixture of aerated oil will be forced into the bearings and in case you didn't know, air is not a lubricant. Typically this means that bearing damage will follow quite rapidly, especially if you are driving on a motorway. You'll know bearing damage when you get it. The engine smells like a garage mechanic cooking over an open flame and the noise coming from the engine is the sort of thing you'd normally hear in vaudeville plays when a piano is pushed down a flight of stairs. As if that all wasn't bad enough, the excess oil gets thrown up into the piston bores where the piston rings have a hard time coping with the excess oil and pressure. It gets into the combustion chamber and some of it will get out into the exhaust system unburned resulting in a nice patina of oil all over the platinum surfaces of your catalytic converter. This renders it utterly useless for good."
    Of course once the oil starts leaking it does become something of a self-correcting problem, but if you don't notice it, you then get the problem of insufficient lubrication.
    I think the feeling among mechanics, particularly ones familiar with an older era when bearing seals weren't as good, might be, 'I'll overfill slightly so it still has plenty once it's leaked a bit." Modern bearing seals are oil-tight against the recommended grades of oil (API SL, SM). There is a MAX mark for a reason. Stay below that mark.
    A conspiracy theorist might consider that the dealer deliberately overfills the oil to cause a leak and therefore give themselves regular work... but I am not a conspiracy theorist. "Never ascribe to malice that which can be adequately explained by incompetence."
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Or, as I like to say:
    "Why do it correctly when it's so much quicker and easier to just f*** it up?"
