Engine Rod went - 2017 prime
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by monte b, Jul 11, 2023.
  1. monte b
    monte b Junior Member
    I have not posted in here for quite some time I have a 2017 Prius prime my antifreeze or overflow was leaking. I bypassed the main system and it seem to be fine with no leaks. Long story short the antifreeze was going into the engine and I blew rod, does anyone know where to get a used Prius prime engine from that’s not 3k
    I have 155k on the car & commute 200 per day -
    49,397
    Wow, sorry to hear it, all the best!
  3. Mendel Leisk
    38,653
    For forensics:
    Was the leak in the exhaust heat recovery system?
    The system being exhaust heat recovery system?
    Long story would be good: is there evidence of head gasket failure, or did coolant level just run low, engine overheated?
    That’s a piston arm? Can you post another pic, showing larger area? Hard to tell location/orientation.
  4. Leadfoot J. McCoalroller
    7,138
    6,684
    Pennsylvania
    2018 Prius c
    Tried LKQ?
    car-part.com?
    <local scrapyard> I don't know your location
