Engine running rough
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rich12, Jan 1, 2014.
  1. Rich12
    Rich12 Member
    176
    29
    I decided to run a 2 tanks of E25 though my Gen 2 and now I've been noticing its running really rough at idle: no check engine codes, though. MPG is fine and I cant hear the clatter at speed or during acceleration. Sounds much worse than the usual ICE clatter. 110k and oils is fresh.
    Sounds like the engine has ball bearings going though it...best way to describe it.
  2. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi Rich. Some people describe the sound of pre-ignition (pinging) as a bit like marbles or ball bearings rattling in the heads. The strange thing here however is that pre-ignition is usually most noticeable under high load, particularly high load at lowish revs. So it might not be the problem, but it wouldn't hurt to try a tank of premium (higher octane) just to see if it has any effect.
  3. salguod
    salguod Member
    234
    37
    Columbus, OH
    E25 as in 25% ethanol? Is it OK to run more than 10% ethanol in a Prius?
    Ethanol has a much higher octane rating than straight gas, I'd bet that E25 is higher than premium gas. Not likely a knock problem, but it is possible that it wouldn't run well on that much ethanol.
  4. Rich12
    Rich12 Member
    176
    29
    Yeah it's 91 octane and 25% ethanol. It's still running rough even after a tank of regular. Any suggestions? Could this damage the engine?
  5. bisco
    49,715
    hard to figure what damage could have been done. you might have to try a process of elimination, spark plugs, injectors, throttle body and etc.
  6. Rich12
    Rich12 Member
    176
    29
    Thanks. Really.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Why the 2 tanks of e25 anyway? Were you chasing an engine issue? Throw a code? Probably just needs a good throttle body & maf clean.
