Engine runs while in B
Discussion in 'Gen 2 Prius Technical Discussion' started by IABoy, Sep 21, 2010.
  1. IABoy
    IABoy Junior Member
    36
    Iowa
    OK simple question, when I coat to stop using B why does ICE continue to run instead of turning off? If I move lever to D then ICE shut right down. Other than as a reminder "Shift the lever, dummy", why would/should ICE continue to run in B but not D when stopped (assuming battery does not need recharge)?
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    First, why are you using "B"? It is only for simulating engine braking on long downhill runs.
    "B" often runs the ICE to use up excess energy, but running the ICE while stopped has no purpose unless your HV battery is is discharged (as you mentioned) or the ICE (or Catalytic) needs heat.
    JeffD
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Don't use B. I can't imagine where in Iowa you need to use B mode.
    As for shutting down, B mode uses the ICE for engine braking. Presumably it is kept spinning to be able to immediately shift to braking, although it could be just an interesting artifact. Likewise shifting to N will keep the ICE from shutting down.
    Tom
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I've found the engine will run when in B if I've decended a long steep hill, though it seems to do this only when the HV battery is very very full.
  5. qbee42
    18,058
    3,074
    Northern Michigan
    This is correct, although "run" may be a misleading term. In this case, the Prius control system spins the ICE as a big air pump to throw away excess charge in the battery. The ICE isn't running as in using gas, it is being spun by MG1.
    Tom
    2 people like this.
  6. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    There are some Iowas river towns with interesting street grades, like Snake Alley in Burlington. I've walked it but not driven it. They aren't long enough to "need" B but following the "use engine braking to maintain speed and the brakes to slow down" criteria, they are a reasonable use of B
    The locals claim it's the crookedest street in the world, but we all know that Wall Street actually holds that record.
  7. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    I echo Jeff and Tom.
    A clarification on B mode: The ICE will not run if you shift into B at speeds below 20 MPH and stay there. It still offers added drag down to about 7 MPH, with that energy going exclusively to added regeneration (well, minus conversion losses).
    See this for a complete description of B mode:
    http://www.techno-fandom.org/~hobbit/cars/b-mode.html
    Hobbit describes in this paper the running-while-stopped-in-B condition but states that no one really knows the reason for the design.
  8. IABoy
    IABoy Junior Member
    36
    Iowa
    Thanks to all for the info.
    I had been told by several local Prius owners that they always use B to slow the car whenever coming to stoplights/signs (and of course down hills). Claims save some brake wear and tear, which made sense to me.
    As for Burlington street, we drove it in a big ole battleship station wagon one time. You put it into low and keep foot on brake as needed to the bottom. Also coming into Dubuques there are several long decents where that HV battery really gets a charge up, though never have seen the gauge go to completely all green bars.
  9. Patrick Wong
    18,200
    6,472
    Friction brake wear & tear should be a very minor worry for Prius owners since regen braking takes care of most of the braking load until the car is down to a single-digit speed. To the extent that brake maintenance is an issue, the problem more likely is that the brake discs need to be replaced due to lack of use and rust forming on the disc surfaces.
    By shifting into B, you are wasting energy spinning the gasoline engine that otherwise would be directed into the traction battery.
    I have >110K miles on my 2004 and the original brake pads still have plenty of thickness left. I will probably change them at around 140K if I keep the car that long.
    When on a long descent, you don't have to worry about excessive friction brake wear until you see eight green bars on the SOC gauge. When you get to that point, you'll notice that the transaxle automatically shifts into a quasi-B mode even if the shift indicator remains in D, as the engine will speed up to consume energy that no longer is needed to charge the friction battery.
  10. IABoy
    IABoy Junior Member
    36
    Iowa
    Thanks, learned something new how the Prius works.:D
  11. fuzzy1
    10,167
    At the downhill speeds I use B mode, above 20 mph, ScanGauge reveals that the ICE always spins. But it doesn't start impersonating a jet engine until the battery is full.
  12. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I tested this, and the engine does indeed not shut off if you shift to "B" and come to a stop. Regardless of the state of battery charge.
    I wouldn't use "B" to try to enhance braking though. If you brake early enough you can use more gentle pressure on the pedal and keep it in regen rather than friction braking until you get quite slow.
    I only use "B" when descending long mountain pass'. I'm talking of more than a mile to the bottom. That's what it's for.
  13. richard schumacher
    7,663
    1,038
    United States
    (D'ohh!! somebody mentioned "N".) IABoy, note that in "N" the engine cannot recharge the battery. Don't use it except when being pulled through an automatic carwash.
