Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Not a very good first post.... i recently sold my 2009 to get something a little newer. Turned out to be a mistake. I got a 2010 at auction with 118k miles. I bought it at an auction and they claim it ran and drove. I put a new 12v battery in and and had no luck getting it to run. The only code I get is crankshaft sensor. After spending all day on it and almost 5000 dollars, I log onto Toyota's owners page and find out that over a month ago Toyota believed this engine to be seized. Either way, someone screwed me but now I'm curious what you think I should do?
    My code reader only shows a crank sensor code but the Toyota write up shows others. I.will try to attach it.
  2. PriusCamper
    PriusCamper Senior Member
    13,070
    5,306
    Pacific Northwest, USA
    Hopefully you got a good price? On the bright side engines from wrecked Prius are in the $1200 dollar range and I saw a post on here this week of a mechanic who swapped an engine in 4 hours. Probably most nobody can do it that fast, but the cost of getting this one going again is way less of a cost/challenge than most other cars...
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    My initial thoughts about that diagnosis is that they're idiots. But having not been there, who really knows. Personally, I think there's something other than a seized engine going on. Like maybe the crank sensor went bad, so the engine will not start? Like with an unkown crank position it doesn't know when to spark? (in simple terms). Like maybe the HV battery drained while they were driving 30mph with no engine running. Like depleting the battery made the car go slower and slower until it died. But, I could be wrong. Wouldn't be the first time. Maybe it threw a rod and broke the sensor face. But then it would also be likely the rod would have violated the side of the block or oil pan also.
    What did you do to it that cost you five grand?
    Data Daedalus, PriusCamper and m.wynn like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Based on the description there, I wonder if the inverter isn’t the issue.
    Look in the vehicles history for the IPM software flash.
    Do you have access to Techstream? Or what code reader are you using? If it is the inverter or something related to the hybrid drivetrain (which is where the dealer was going by calling for a hybrid tech), you’ll need a more advanced code reader to get a full picture.
    But ultimately buying cars at auction is a risky business. What were the terms of the purchase? Do you have any recourse?
    Good luck and keep us posted (y).
    Data Daedalus and m.wynn like this.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I would jack up the right front and remove the splash shield. Then attach a socket, extension, and breaker bar to the crankshaft bolt and see if the engine turns. Should turn fairly easy until you hit engine compression. Then it will get tight, and loosen up again until the next cylinder comes up.
    If this passes, then follow up with getting the inverter tested.
    If the engine is indeed seized, it can be replaced for around 1k (used) if you can do it yourself. Plan on 2k to 2500 if someone does it for you.
  6. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Gotta love semi-literate service record entries:rolleyes:...
    Seized seems unlikely to me, but hydrolocked could certainly impersonate seized.
    Data Daedalus and Raytheeagle like this.
  7. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I paid 4800 for it because I was told it ran and drove through the auction. Then I bought a battery. The scanner I am using is a snap on solus. I don’t know if I would go down the road or swapping engines due to time available right now. I am under the impression after ready the reports that a hybrid tech did look at the car.
    The auction company loaded it on my trailer with a loader. When I got back and tried to start it it didn’t run. I called and asked them to take it back but they said once it leaves the property I’m screwed. Little unfair considering they dropped it on my trailer. Oh well.
    If I restart the system by disconnecting the batter, the car seems like it’s going to work. It shows three bars on the hv battery. Goes into ready mode. Then after a few second drops out and and throws the check hybrid system message. After that it only goes into ready mode for half a second they drops out. Once it is in this error mode it shows 1 bar on the hv. If I try to move the car when it’s in ready it will move until it drops out. It seems like it starts to try and turn the engine then drops out. It has 2/3 of a tank.
    m.wynn likes this.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Reading this post, it does sound as if the engine is seized. Probably popped the head gasket and filled a cylinder or two with coolant. Then on ICE startup you get bent rods and/or broken pistons.
    m.wynn likes this.
  9. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Here is the crank sensor. Does not look damaged or caked with anything. I will test it with ohm meter in a bit.
    Engine rotates freely
    #9 Jamesmlemay, Dec 1, 2018
  10. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Don’t forget you are on a pitch count as there is only so much juice in the hybrid battery.
    If it is at 1 bar, you need to get it recharged before you can continue with anything else.
    edthefox5 and m.wynn like this.
  11. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    Here's info to ponder....
    Tried to start car multiple times with a failed crank sensor...how many tries is the HV battery good for, before it's SOC is too low?
    Disconnect the 12v battery and guess what? The HV battery display/ecu goes to a default value (3 or 4 bars) since it really doesn't know the true SOC.
    Now try to start car again. Drain battery even more. Rinse and repeat until the HV battery is essentially a paperweight.
  12. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    What’s the least expensive way to get it charged up? And it’s weird. When I pull the 12v and reinstall it shows more than half on the hv. But after the error it’s down to 1
  13. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I didn’t know it defaulted. That’s true. Bummer so I probably smoked the battery.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Your local Toyota dealer should have an emergency grid charger. I called mine when I did my engine swap. They were going to charge me like 179 to grid charge it. But my hv battery had enough juice to start the ICE.
  15. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I'm not sure that im in the correct range on my multi meter but my crank sensor is only measuring out to be 0-2.1 ohms between the two prongs
  16. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    It is probably reading 2.1 thousand which would mean it's in speck as it is the ohm symbol with a k
  17. PriusCamper
    13,070
    5,306
    Don't worry, it's unlikely you damaged the battery, it'll just be too low of a charge to turn the engine...
    First, make sure you know your high voltage safety rules...
    Then, use a meter to measure the voltage of the pack so you know where' you're at. Not sure minimum voltage to turn the engine over is, I need to find that...
    Next, you can buy a grid charger ($400) via hybridautomotive.com, which is a bit expensive because the additional $150 wiring harness they sell has a box that imitates the hybrid battery ECU for the purposes of controlling the pack's cooling fan.
    A less expensive, but more time consuming route is to pull the pack and charge each of the 28 individual 8.2v modules with a smart charger for NiMH batteries. There's lots of options for chargers, the most commonly used one on here is: IMAX B6AC V2
    Or just head to your local RC car and drone hobby shop and see what they have. Also if you want to speed up the process you could wire the whole pack up in parallel and charge the whole pack up to 8.2, but that's not as thorough as doing each individual module so you're certain all modules are in good shape and you have a balanced charge.
    Of course finding out what's wrong with the car and fixing that before you work on the pack would be wise. Also learning about reconditioning NiMH packs would be a good way to increase battery pack capacity and increase overall longevity: BU-807: How to Restore Nickel-based Batteries – Battery University
  18. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Okay thanks. I feel like it needs to be charged to get a accurate diagnosis on what's going on. The crank sensor tested good on ohms and created it's own voltage so I reinstalled it. The car would move a foot or so when I tried it when I first got to it.
  19. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    My friend has a prius he's rebuilding. Would I risk doing any damage to either car if I were swap batteries between them?
  20. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Remember the battery only has so much voltage.
    But your friends could work if he allows you to swap a battery into his car that he’ll have to deal with.
    Between the 2 Prii you and your friend have, the Prolong equipment from Hybrid Automotive might be a good deal going forward.
    Good luck and keep us posted.
    davecook89t and m.wynn like this.
