Engine shake after long drive
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrtoofay, Nov 18, 2020.
  1. mrtoofay
    mrtoofay New Member
    rowland heights
    This happened just today. I drove from Los Angeles to San Diego, about 120 miles. Everything went well. After stopping to sign a contract with a client (which took about 30 minutes) I started the car up and got ready to drive back to Los Angeles. The ICE kicked in, and then started to shake very violently. I turned the car off and restarted again. The ICE kicked in again and started to shake very violently. I floored the gas pedal and then it stopped.
    After driving 120 miles back, I stopped the car and went to second client to sign another contract. This time the car was stopped for 45 minutes. The ICE didn't start til after I backed up and pulled forward. It shook very hard again. I floored the car and everything went back to normal. Drove another 90 miles and everything went fine. Stopped by my office and the car rested for 4 hours.
    After 4 hours, as I braced for the worst, the car started just fine with no shakes whatsoever. Stopped by the market on the way home, about 10 miles later, for about 15 minutes, and the car started to go just fine as well. After pulling out the parking lot, the engine stumbled just a little, perhaps 2 seconds, as the ICE kicked in.
    MPG and power all feels the same. Spark plugs were changed 1000 miles ago.
    From my searches on the forum, I gather that it may be one of the coils? or EGR needs cleaning? I under the coil issue, but EGR? Does clogged up EGR effect the engine right as it starts? I've been wanting to take the EGR apart to do a total cleaning, but with COVID, my businesses closed down so I have to get 3 different part time jobs to get by, haven't got a chance to do so.
    Thank you in advance for any advise.
  2. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Without history of car and mileage provided, my worst guess is that the engine has a blown head gasket and you need an engine replacement. Or just buy a new car.
  3. mrtoofay
    mrtoofay New Member
    rowland heights
    Purchased the car at 160k miles. Had an indy checked it out, everything seems fine. It's currently at 175k miles. Oil is clear, not milky, it's not gaining or losing oil.
    Do you mind me asking why would you come to the conclusion of blown head gasket?
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Watch the coolant level and have someone look for steam coming out of the tailpipe with the engine rev'd up a bit. Either one would suggest an unfortunately fairly common head gasket problem. If that is the problem, coolant is getting into the cylinder and fouling out the spark plug. Usually it is worse after it has been off for awhile. Then the cylinder starts firing and you are good temporarily. Depends somewhat on what position the piston has stopped in and if the engine is warmed up. Other possibilities are oil slugging from the pcv dumping into the intake manifold, coil or injector problems. Usually the alternatives don't present the same.
    I would get it checked as soon as possible because head gasket leaks can hydrolock a cylinder, bend rods and sometimes end worse. A dealer diagnosis may be best.
    There is a head gasket mobile service out of the San Jose area that will likely come to you if that is the indication. Gasketmasters. They have youtube videos as well. Dealers and many mechanics will often suggest a used or new engine if there are a lot of miles, any sign of overheating or the problem has existed for any length of time.
    #4 rjparker, Nov 18, 2020
  5. mrtoofay
    mrtoofay New Member
    rowland heights
    Thank you for the reply. Just went outside and checked again. Oil on dipstick clear and at full mark. Coolant at full mark as well, as the engine is still warm. I understand that if it's the dreaded head gasket, it's cheaper to find another car, or hunt down a used engine and have an indy install it. If.... IF... IIIIFFFFFFF.... it's the head gasket. Is there any difference in going to the dealer to have it diagnosed now? or drive it til the engine tears itself apart? Other than getting stranded on the side of the road? I've sent gasketmaster a message to see if it's feasible to have time come down to do the change even just as a preventative measure.
  6. rjparker
    7,975
    4,716
    Texas Hill Country
    First IF the head gasket blew today, not much coolant will have been burned so far. IF it is a typical gen3 failure the coolant goes into a cylinder and out the tailpipe, not into the oil. I would spend the diagnostic $100-$150 so you know if its a less expensive problem. I would also ask them to check for any signs of a head gasket sealer that the seller may have dumped in. Those will often mask the problem for three to six months.
    I have read that Gasketmasters charges around $2k which includes a reworked head, a big plus. IF it is a head gasket, driving it will ruin the engine for sure and will likely strand you. Since you have already made improvements on the car since you bought it, don't give up yet. Get a diagnosis.
  7. abdullah arslan
    180
    77
    I recommend you to do this test,
    I ll do it, too. I like Scotty's approach in general
  8. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Because when mileage and history info are provided, we get a better idea what could be causing the issue. Without the info, it’s a great way to scare the living crap out of the person as they withhold the info :ROFLMAO:
  9. mrtoofay
    mrtoofay New Member
    rowland heights
    Started the car and stood behind it for a few minutes. Smelled the familiar sweet smell of burned coolant, so I contacted gasketmasters and was told not to run the car since it's very likely it's a headg asket issue. Quoted $1550 to come to Socal to fix. But when I asked him when he could come, didn't get a reply.
    Stopped by the local prius shop that took care of my batteries previously. He confirmed head gasket by opening the coolant reservoir while it was hot. Mentioned that if there's an issue with the head gasket, the pressure will be higher and the hissing would last much longer than a healthy engine. Coolant level has dropped almost an inch since last night. Was quoted $1200 for a head gasket job. He mentioned that since the cylinder had water in it and couldn't compress, there's a good chance that the piston rod could be bent. Pulled one of the rods from a car in the shop and showed me. Quoted me $1800 for a rebuilt engine installed. Which he just happens to have one sitting on a crane about to be installed on the prius with the bent rod. Since I need a car to drive around, asked him to give me that motor and was told that my car would be done by tomorrow 12pm (it was around 11am when I went there). Also asked him to make sure that the EGR system is cleaned out as well.
    Fingers crossed that everything will go well. Anything I should ask or examine when I pick up tomorrow?
    Thanks for the input and the gasketmaster referral. If i have a second car sitting around, I would've waited for their response.
  10. rjparker
    7,975
    4,716
    Texas Hill Country
    Can't beat those prices or service time. They must know their business. I would ask what parts were rebuilt or replaced in that engine and the year it came from. Also what guarantee they provide.
