Engine Shutter @ 45-50 Mph
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TwoPriusInTenn, Jun 28, 2025 at 7:34 PM.
  1. TwoPriusInTenn
    222
    61
    Tennessee
    Greetings,
    Wife's 2010 with 428,021 miles.
    I replaced the head gasket on this car in 2019. My daughter has had it in Florida. Came down this weekend to change the oil and sparkplugs. I also cleaned the EGR Cooler. (preventative).
    When I was done, I took the car for a drive and it shuttered at 40-50 mph. I checked TechStream and tthere was misfires in Cylinders 2 and 3. Switched around the colis and Techstream is still registering misfire in Cylinder 3,
    I'm thinking the headgasket might be gone again.
    Anything else I should check before throwing in the towel on this?
    Tombukt2 likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    12,121
    2,142
    Durham NC
    Nope you pretty much got it we had a persona did this twice . No fun
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,554
    1,640
    Bay Area
    any coolant leak? That should indicate it.
    Any cold start shutter? How are the fuel injectors? How does the spark plugs look?
  4. Grit
    Grit Senior Member
    6,431
    4,182
    Wilkes Land
    Leak down test. If it passes throw parts at it. If it failed, trip down to head gasket replacement again.
