Engine slighty rattle during accelerating
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A617, May 11, 2014.
  1. A617
    A617 Member
    213
    95
    OKC, OK
    So lately I've been hearing what sounds like a slight lifter knock that develops at 1500 rpm to 2700 (I have ultragauge) when accelerating or maintain speed, and it only appears when the engine is at operating temp and disappears when rpm is below 1500 rpm and above 2500 rpm my oil is running at 3900 miles using Toyota synt 0W-20 and it looks pretty clean and at high mark of the dip stick, Does anyone else experiencing this sound?
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I heard a definite knocking sound today when my wife accelerated gently away as I was standing nearby.
    The car was at operating temperature. I was surprised, because I assumed most of the load would be taken up by the electric motor(s) and not the ICE.
  4. A617
    A617 Member
    213
    95
    OKC, OK
    I'm thinking that since we use Thinner Oil it doesn't drown out the mechanical tapping of the cam shafts, that's the only possible cause of the problem that i can think off, the fix could be using slight thicker oil during summer time like 0w-30 and the switch back to 0w-20 for winter.
