Engine Start Battery
Discussion in 'Gen 3 Prius Main Forum' started by CharlieQ, Oct 31, 2018.
  1. CharlieQ
    CharlieQ Junior Member
    24
    31
    Belleville
    Hi Everyone ,
    Just wondering how long everyone's original start battery is lasting . I have a 2012 Prius with 429,000KM on it and is still using the original start battery. I don't usually get that type of live out of a battery ( 7 years). Wondering if I should change it on spec or just keep driving.
    This has been the most reliable car I have ever owned . I follow the scheduled maintenance and the only failure of any type has been two wheel bearings. One at 380K and one at 385 K. I am going to see if I can put 1 million KM on it .
    Thanks
    Charlie
    51,140
    yours is proof that prius like to be driven. i also have a 2012, but only 60k. no issues, and i keep an eye on the battery with a volt meter, instead of worrying about when i might need to replace it.
    our 12v experiences seem to be unusual however, as most here seem to only get 4-6 years.
    the key to success imo, is never letting the battery drain. that shortens the life span dramatically.
    my last two prius 12v lasted 8 and 10 years. it is said that warmer climes are harder on battery life.
  3. davecook89t
    davecook89t Senior Member
    1,076
    810
    Washington State, Florida
    Four Touring
    I think most forum members would say if your battery is 7 years old, it's time for replacement. If you decide to risk driving it a little longer without a new 12V and wait until it starts to give you problems, at the very least you should carry a jump kit somewhere in the passenger compartment. It should be one that has a chip that senses polarity before it allows current to pass to your battery. This will prevent damage to your inverter that could result from having someone jump start your car incorrectly. It should be carried in the passenger compartment so that if the car fails to unlock using your remote due to the 12V being too weak, you can use the physical key to open the door and then connect the jump kit to the correct jump points under the hood, rather than having to crawl through the car to reach the jump kit in the luggage compartment. You could perform a load test on the battery to be sure that it needs replacement, but at this point it would probably fail. If you continue to drive with a weak 12V, with the added security of having a jump kit with you, be aware that your MPG will suffer and the car may show misleading warning lights from time to time. The problem with constantly seeing warning lights on your dash is that you will never know when you have a real problem. I understand your compulsion to try to get the last bit of life out of the resources you have. It is commendable from the point of view of trying to preserve your finances and the environment, but maybe it's better to just let the 12V go.
    Congratulations on caring for your car well enough to get 429k km and 7 years out of the 12V.
  4. Mendel Leisk
    40,574
    Spring for something like Solar BA5, see where you stand.
    That's unreal kms btw. have you ever cleaned the EGR, intake manifold?
  5. CharlieQ
    24
    31
    Belleville
    Mendel,
    I changed the EGR value at 400K KM when I was having my second set of spark plugs installed . They were in the area anyway doing the spark plugs but they told me it was not an easy job.
    EGR value is not in the maintenance schedule but I am a little old school and remember how bad they would get on my1963 slant six dodge. That was the one with the push button transmission.
    Now I have dated my self.
    Charlie
  6. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    I had 8.5 years on our 2010’s battery when I swapped it out at the beginning of 2018;).
    They do last if you don’t discharge them(y).
    #6 Raytheeagle, Oct 31, 2018
    Bay Stater, Grit and m.wynn like this.
  7. davecook89t
    1,076
    810
    Four Touring
    Are predicting the future, Ray, or doing some time travelling?;)
    Raytheeagle and Grit like this.
  8. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    He’s from the future :cool:
    Raytheeagle likes this.
  9. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Sorry, should have been 2018:unsure:.
    I use an iPhone 5s and the keyboard leaves something to be desired when you type with your thumbs:cool:.
    Amended above(y).
    davecook89t likes this.
  10. DeezPrius
    DeezPrius Junior Member
    32
    OC/Riverside CA
    Are there any signs before it finally drains and you can't start the engine?
    I have a 2010 and previous owner changed the battery in 2014. Per Toyota service records, previous owner tried to start the car but couldn't and had it towed it.
    I want to prevent that from happening to me and take care of it right away.
  11. davecook89t
    1,076
    810
    Four Touring
    There are plenty of signs the 12V is dying, including warning lights on the dash (typically the ABS and VSC lights, but be aware that they may appear for other problems as well), difficulty unlocking doors and weak headlights when the car is not in the Ready mode, but why play a guessing game? Buy a Multi-Meter for $10 to $20 and check the voltage of the battery at the jump points under the hood. You should see a voltage of 12.5V or better when the battery is at rest. (Open the hood, lock the car, move the key out of proximity range, and then measure the voltage after a few hours). Better yet, get a jump kit as I suggested to the OP in #3. For less than the cost of a tow or a diagnosis at the Toyota dealer, you can have the peace of mind that you will not need a tow for a dead 12V. Additionally, you can safely help out a friend by using the kit to jump start their car, if that's what they need, something that should never be attempted from the battery on your Prius.
  12. Mendel Leisk
    40,574
    Test it with something like a Solar BA5. It'll measure the voltage, the Cold Cranking Amps (or Cranking Amps, or a few others), and give a verdict on it's health. They're around $50~60.
  13. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I had to double check my service history but it looks like we replaced the 12v with about 7 years on it (purchased the car new in 2010.)
    I had to jump it (used a jump pack) one very snowy morning so I had the dealer put in a new Panasonic-Toyota OEM. A bit more money than if I had done it myself, but I was recovering from a long surgery debacle still and it was really cold and snowy so the extra $$$ was worth it.
    We get good life out of our car batteries here in the cold/temperate climate. I replaced the 12v in my 2005 4Runner last winter, it was the original equipment Panasonic. :eek:
  14. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    I have 2010 Prius III. (Manufactured 07/2009, First use 08/2009). The original battery died past June (2018) with no prior warning or symptoms(The car just wouldn't power on). So that makes it almost 9 years. And all of this is in Florida heat. I guess the reason they last much longer is because they only power electronic devices and some small electric motors (electric window, cabin fan etc.) No excessive power demand as starter motors require. Thus they last till they have very little power left in them.
    I don't replace vehicle batteries under preventative maintenance while they are still working fine. They get replaced when they die. And the thought of "I might get stranded someday somewhere..." doesn't bother me. Because it can happen for many other reasons.
    DeezPrius likes this.
  15. Mendel Leisk
    40,574
    I think a faltering battery can impact mpg, the hybrid battery has to devote more and more juice to keep it going?
  16. iskoos
    403
    251
    Orlando, FL
    That could be a viable theory. The best is to perform a load test as you suggested. Voltmeter will not be reliable.
  17. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    There's lots of anecdotal evidence that a weak 12v can cause all kinds of wonky issues with a Prius including intermittent warning lights and odd behaviors. It may not have a lot of power, but it does key a bunch of electronics and a weak signal there can cause issues.
