Engine started while changing oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joedroid78, Aug 9, 2014.
  1. joedroid78
    joedroid78 New Member
    I recently bought a 2011 Prius two from an independent car sales shop. After 2k miles, I thought I'll replace with Mobil 1 synthetic. I'm doing the oil change for the first time and made a rookie mistake. Car on ramps, assuming the car was turned off (in fact, it wasn't), I removed the drain bolt and filter. Oil was almost drained and suddenly the engine turned on. I scurried over and turned it off, probably in 6 or 7 seconds. Car runs fine now. But, I just want to know what damage my silliness would have caused the engine. Any inputs from the wizards here will help.
    Thank you folks for the time.
    Joe
  2. gliderman
    gliderman Active Member
    751
    223
    Great first post!
    Your lucky it didnt fall off the ramp.
    Dont do that again!
  3. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I have to believe an engine that idles with only residual oil for just a few seconds will be fine. I'd be very surprised to find out this results in any problems whatsoever.
    I wouldn't worry about it.
    #3 KennyGS, Aug 9, 2014
  4. ibmoses
    ibmoses Junior Member
    109
    22
    You could get the oil analyzed next time you change it and see if any warning signs in the sample you submit.
    Other than that about all you can do is drive it and listen for strage noises(rattles), maybe listen very closely when the engine is first started...
  5. Okinawa
    Okinawa Senior Member
    1,333
    317
    Ask the advice of Patrick Wong.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    6-7 seconds? You'll probably be fine but keep an eye out for increased oil consumption or smoke or both.
  7. Beachnut
    Beachnut Member
    185
    43
    I bet it will be no problem! How hard was the oil change on ramps? Do you have the cartridge filter like our 2014 has? I am stinking of doing the first oil change at 5k miles, so your input might help. Thanks, and ever glad it stayed on your ramps!!!
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Nice scramble :)
  9. Former Member 68813
    3,524
    981
    US
    I'm surprised you didn't hear the inverter buzzing while on.
    Totally harmless at idle speeds. This is why you can harmlessly flush engine with kerosene (non-lubricant) at idle speeds.
  10. joedroid78
    Thank God that it did not come off the ramp (it was on parking though); I'm very lucky. Nice to read that some of you feel that it is harmless. A friend of mind came in just as I rode the car on to the ramp and I got distracted, man this won't happen again.
    This is my wife's prius and I was using it (while she is vacationing at her mom's) as my allroad gives horrible mileage. I started falling in love with this car; that I thought it would be nice to give her a nice new engine oil change and save some 50 bucks over stealership. I need to make sure all is well before I tell this to my wife, else she will literally and physically rip me into pieces and this will be the last time I ever touch the prius.
    As okinawa suggested, I'll wait to see if Patrick Wong responds here, else I'll PM him; not sure whether he will like it though.
    Cheers fellas :)
    This also clears a myth/rumor that a prius will not start when engine oil is low. At least i know for sure that this is not true with a 2011 Prius two.
    #10 joedroid78, Aug 9, 2014
  11. ibmoses
    109
    22
    Dude, trust me on this.
    Some things she does not need to know.
  12. Okinawa
    1,333
    317
    Sounds like you have been in trouble by telling too much. LOL. Me too. I have learned the hard way several times. I volunteer nothing now.
  13. bisco
    49,446
    the synthetic really does a great job of coating the metal surfaces, you'll be fine. glad you didn't get hurt!(y)
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    Paraphrased: Being quiet saves one from having to unsay something.
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Wise man say when in deep sh-- keep mouth shut.
    MexicanChip likes this.
  16. Okinawa
    1,333
    317
    And don't tell mama anything,!!
  17. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    It takes more than 7 seconds without any oil to ruin an engine. My friend intentionally ran his car without oil to try to blow up his engine. It took him a good half hour before any unusual noise could be heard.
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Whilst I agree it is very hard to seize an engine these days whilst trying, long term damage can be caused quite quickly causing oil consumption and/or burning smoke. I do appreciate what you're trying to say and the OP has probably got away with it.
  19. Former Member 68813
    3,524
    981
    US
    Yes, because there is a residual oil film on all surfaces. It should protect for a few minutes (but not under heavy load!).
    When they did the mass killing of used car (cash for clunkers), they drained the oil AND put liquid glass inside.
  20. tv4fish
    tv4fish Member
    202
    46
    Anybody else remember the commercials for "Slick 50" ??? :)
