Engine starts runs briefly shuts off rattle
Discussion in 'Generation 1 Prius Discussion' started by windrider, Jan 24, 2015.
  1. windrider
    windrider Junior Member
    Honolulu HI
    2002 Prius
    I
    Hi everyone
    I searched and got some info but have not fixed this yet
    03 classic prius gen 1 166k miles
    The car ran fine and sat up for a month in my garage
    Started car ran about a minute engine shuts off rattles then traingle code comes on
    While running in drive or neutral acceleration pedal does not speed up engine either.My 02 will slightly Rev up in drive if you push accell pedal
    I have codes p3191 p3101 on toyota pc scan . cleared problem returned, codes returned
    Now the traction battery (which was brand new) is low.
    I'm looking at ordering a special hv charger yes I have gloves and experience
    So far
    Added gas 3 gallons
    Auxiliary battery fully charged
    Cleaned mass air flow sensor
    Checked connectors at various areas and ecm plug
    I did find something strange at engine**(?) ecm on right side .. ecm plug lower two connector plugs had oil ? in them not sure how oil ( if that's what it is)could get in this area at all
    Could have been from anti corrosion gel not the ac evap... it's away from that area, doubt it, maybe from inside the ecm it self brown color prob old silicone grease?
    I cleaned the oily brown goo off the ecm plugs and pins same result engine shut off after 30 seconds or so
    Now that the traction battery is dead will have to wait for a charger to start it up again.This is a brand new rebuilt battery never ran enough to fully charge from Dorman.
    The old battery worked but had some leaky cells getting electrolyte to ground
    Car was still running ok then sat up.
    I still need to check fuel pressure compression and spark
    basics suspect moisture in spark coil but car was in garage
    Saw several posts to clean throttle body so will do some cleaning tomorrow.
    I'm an electric and mechanical guy so normally can find stuff
    I've been reading the prius posts and learned quite a bit.
    I rebuilt 2 traction batteries and got 2 old school gen 1 prius are on the road. Found bad cells replaced car ran 1 year,other car did battery and replaced an mfd in one
    My first 2003 I fixed drove a year then it sat up... now new problem
    #1 windrider, Jan 24, 2015
  2. Patrick Wong
    18,210
    6,513
    DTC P3191: Engine does not start, logged by engine ECU
    DTC P3101: Engine system malfunction, logged by hybrid vehicle ECU
    1. Clean the throttle body interior and throttle plate. Remove the air cleaner housing for access. Spray some throttle body cleaner on a clean cloth and use the cloth to scrub the throttle body interior and throttle plate. Rotate the spring-loaded throttle shaft for access to the edge and bottom of the throttle plate.
    2. If that doesn't help, remove the spark plugs and check the condition of the plugs and spark igniters. If the iridium spark plugs have more than 60K miles, replace them now using the correct NGK or Denso iridium plugs.
    3. If that doesn't help, measure the fuel line pressure, should be 43 psi or more.
    4. If that doesn't help, check the fuel injectors.
    5. Are you using Mini VCI? If not, get that device so you can see if any other DTC are being logged.
    6. I doubt the gasoline engine was running if you could not get engine speed to increase based upon the accelerator pedal input. More likely, MG1 was spinning the engine and drained the traction battery.
  3. windrider
    Honolulu HI
    2002 Prius
    I
    Hi Pat,
    First of all thank you for your help and response *(and everyone else that contributes to the forum).
    #1- I did some cleaning on the throttle body. It was dirty, looks allot better now.
    #2- then took out spark plugs they looked a bit wide on the gaps some wear, replaced them with new NGKs. No oil fouling or wet fuel on them
    did not take compression test... was saving hv battery charge
    #3- Leaning more towards the fuel supply or even ignition crank sensor now,need to check the fuel pressure next.
    I glanced at fuses other day, may try swapping the fuel relay I think it is the one marked EFI (?)
    Also want to check ohms of MAF sensor
    #4-ok
    #5- Yes VCI w tech stream is great see below
    #6 - I got two more tries at starting, you are right the engine is probably spinning over but not starting... makes sense
    Going to check ohms on the crank sensor. A website "said" 95-1600 ohms cold or 1265 to 1890 hot
    Online manual-
    As with most internet sources I saw the "Toyota workshop manual" website helpful but some of the things are not exactly the same (foot accelerator plug pins 4 vs 6) but still very helpful info and the pictures are nice.
    Codes p3191 and p3101-
    The codes above were from my VCI mini with windows XP, can re-check the codes. Maybe can use VCI to look at the fuel pump+ crank sens.
    I shut it off tonight before it got to where the where triangle comes on
    There was another code in there think it was anti lock brake or something.." c something"
    Charging HV battery-
    On a side note I found a website that said you can charge the HV battery from the side orange connector. Is this right? hum see PDF below
    master tech outofjuice.pdf
    I took this connector out to investigate it...had a plug with three wires,"master tech" said "outside two are hot 300v dc" maybe for gen 2 Prius(?)
    Measured voltage at 19v dc ...not exactly the 280 + v of the main battery wonder if reman people made this wire not live or its disconnected
    Since the battery is new reman and under warranty I did not want to break the seals and void the warranty to charge it.
    I'm looking at the venice hybrid charger 300 v /350 ma $275 :( hope I get it running and don't need it... expensive.
    He also said will have to remove the battery cover to connect it....see above ..
    Hopefully I get the engine running to charge it up before it dies. Car "was running fine before" it sat up a month or so in covered garage.
  4. Patrick Wong
    18,210
    6,513
    3. The fuel relay is aka "circuit opening relay" and it is located in the relay box next to the inverter. That is an easy item to check: find the relay, remove it, use an ohmmeter to identify the relay coil terminals which should measure ~100 ohms. Apply 12VDC to the coil terminals and measure resistance across the relay switched terminals which should be 0.5 ohm or less after you account for the resistance of the multimeter test leads. A new relay will cost ~$75.
    techinfo.toyota.com which is a subscription website, is the source for factory repair manual info.
    The G2 Prius traction battery has no way to access the high voltage without opening up the battery case. I do not know whether the Classic has a suitable connector or not. If you can't measure ~300VDC across the connector, then probably not.
    I imagine that the freight charge to ship the battery back across the Pacific Ocean is high enough so that you are not eager to return the battery unless absolutely necessary. Good luck.
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    You don't need to remove the battery cover to charge Gen1 battery, there is an orange "plug to nowhere" on the drivers side of the battery case. You do need a charger that can output apprx 320V. I have one in Boulder and it's very handy.
    This article is helpful
    http://mastertechmag.com/pdf/2010/10oct/201010-outofjuice.pdf
    If the battery has enough power to crank, try running the car by bursting starting fluid into the throttle body, if you can keep it running more than 30 seconds you know it's not a spark issue so it's gotta be fuel or air.
    If car only runs 8 seconds it never started.
    Rmwilliamsjr and usnavystgc like this.
  6. windrider
    Honolulu HI
    2002 Prius
    I
    Okay first of all thanks Paul for taking the time to talk with me while you were in between. :) I did not remove the throttle body but
    I have narrowed the problem down to the fuel pump.
    I took the time to swap the good charged battery from my running gen 1 Prius to the one that did not run.
    I got my friend to stop by and help, we found spark
    then we held throttle body open and ran it on started fluid briefly so decided no fuel
    Checked and swapped relays and checked the fuses still no fuel, took the line off at the tank and no fuel came out
    Using the wiring diagram we put 12v directly to the fuel pump connector and still no fuel coming out
    Removed the plug on top of the tank but it goes to another connector inside of the tank could not see the pump.
    I started dropping the fuel tank, looks like I will have to remove the rest of the exhaust from the front to have enough room to get it out?
    Not much found about gen 1 Prius fuel pump or anything (so far) even searching the forums at least we found "no fuel" coming out
    Looking online for parts I did not see a fuel pump. is that because the pump has to be replaced with the fuel tank?
    I did see a complete fuel tank for $369 plus shipping ...so looking at options had a generic one as well for more
    hate to put a used but at that price may have to
    Also on a side note:
    Another website had wrong information
    A website that said that you can charge the HV battery by the orange connector on the drivers side of the HV battery is wrong, well not in my case that read 13v so even if I had a 300vdc MNHI charger no way it would charge the HV side.
    incorrect information for my car 2003 Prius classic GEN 1
    #6 windrider, Mar 1, 2015
  7. Patrick Wong
    18,210
    6,513
    When you applied 12V directly to the fuel pump connector, you should have heard the pump motor running. Measure resistance across the fuel pump terminals and see what you get.
    The fuel pump is definitely an integral part of the fuel tank and cannot be separately replaced. If in fact the pump has failed then you must replace the entire tank. However, make sure that you are actually applying 12VDC, and that you are applying it to the correct place, before you give up on the fuel tank.
    C Clay likes this.
  8. 3prongpaul
    956
    730
    Hi Windrider.
    Make sure you can run the car at least 30 seconds bursting with starting fluid. If it only runs 8-10 seconds it never actually started.
    Here's where to apply power direct to the fuel pump (under round disk under rear seat bottom). Double check your wiring and listen for noise when power applied. (click on the A below but apply power to connector B as shown in photo)
    A
    You can definitely charge the Gen1 HV battery via the "plug to nowhere". Make sure the orange disconnect is INSTALLED and measure the two outside terminals with a voltmeter. You should get full battery voltage. If not, your something is wrong inside your battery pack. See this article for more info;
    http://www.mastertechmag.com/pdf/2010/10oct/201010-outofjuice.pdf
    If your fuel pump is bad, you'll need to replace the entire tank (no way to get to the pump itself)...easiest to remove the rear exhaust section first and have the car up in the air a foot or more. There are many hoses and vacuum lines to unhook, just work carefully it's not that difficult. Too bad you're in Honolulu, there's plenty of good (rust free) used Gen1 tanks in California and Colorado, but shipping would be expensive. Ideally you can find a salvage one locally, or you'll have to buy a new one from the dealer. Fuel pumps don't fail all that often so a used tank is probably good. Just don't run the pump for more than a couple of seconds without fuel in the tank, the pump uses fuel its lubricant.
    #8 3prongpaul, Mar 1, 2015
  9. worwalkerlds
    worwalkerlds New Member
    Georgia
    2002 Prius
    Were you able to fix this problem? My 2002 Prius has the same symptoms. I recently had several battery cells replaced in the battery. It will turn over and run for about 15 seconds or so and rattles and turns off.
  10. 3prongpaul
    956
    730
    Unhook 12V, rehook it up then try again.
    Measure the time "it runs" if under 10 seconds it never actually started.
    Scan for codes, if P3101 and P3191 thoroughly clean the throttle body.
    Also try bursting starter fluid into the air cleaner assembly while a helper turns the key to start the car. If you can get the engine to run 30 seconds or more by bursting starter fluid you have a fuel delivery problem. And of course check there is gas in the tank...I had one customer that self diagnosed they needed a fuel pump but they simply had no fuel in the tank.
    bwilson4web likes this.
  11. worwalkerlds
    Georgia
    2002 Prius
    drbojo likes this.
  12. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Welcome aboard, but no need to keep posting, being a new member a moderator has to review your post before publishing it.
    Are you a DIYer? If yes, buy or borrower the MiniVCI to pull the error codes if any to better determine what is going on with your car.
  13. Barry CLEMENTS
    Barry CLEMENTS Junior Member
    52
    Did you ever figure out this problem? Love to know because I am having the same problem after my Gen 2 Prius sat for many months unused.
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Start a car that has sat unused can be a challenge.
    If you have some diagnostic test you could gather some helpful info.
    In the meantime, as noted above, how long does tour car "run" before dying? 10 seconds? A minute or so?
    Barry CLEMENTS likes this.
  15. Barry CLEMENTS
    52
    Thanks for the respinse, Eric. Initially, it ran about 5-7 seconds. Then I plugged in an OBDII and got the code P2118 only which indicates either an underpowered or defective throttle body control motor. I cleaned the throttle plate and surrounding areas and replaced a blown ETC fuse (I believe my brother-in-law reversed polarity when trying to jump the car. He denies he did but pretty sure he did because the fusible link was also blown...replaced that too after he said he heard a pop while jumping the car). So now the car will run about 10-13 seconds before rough idling and stopping. The throttle plate doesn't move during that time. In fact when the car is under power, the throttle plate us immovable manually but when not under power I can turn the spring to open the valve. This is all happening while using a plug in battery to jump the car. The 12v in the car is a Delco and is under 7 months old. My question now is whether a dying 12v will starve the ECTM of the 4V it needs to function and thus cause the P2118 code. My multimeter is very eratic on the voltage setting and not letting me set ranges so I can't really trust the jumping numbers I am getting there. Any help is greatly appreciated.
  16. Barry CLEMENTS
    52
    Rather ETCM...Electronic throttle control motor
  17. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    The throttle plate should fight against you when car is powered. If it didn't fight you, then that would be a problem. (Had a car with that issue once. Ended up being a Brea in the wire harness somewhere. Ended up bypassing a single wire.)
    Of it dies so quickly, then in reality it never really started. Power comes out of HV battery and goes to the electric motor to spin up gas engine, so gas engine spins because of the momentum, but never really starts up.
    Every time you use the battery to spin the electric motor you drive down the voltage of the battery.
    It only take a few tried (5 or less), before the HV battery voltage is too low. At that point you would need to find, borrow, buy, or build a HV battery charger in order to bring the voltage back up to the proper range.
    When trying to start the car have a can of starter fluid, spray it down the throttle body before turning the key. Keep spraying to keep the car running, stopping every so often to see/listen if the gas motor is starting to take over.
  18. Barry CLEMENTS
    52
    My neighbor with a 2008 Prius with 169k miles is now having the same problem with car seeminglyvstarting for about 10 seconds the rough idling to a stall. She has seen me under the hood of my Prius rrcently and asd me to take a look. I used the starter fluid trick and eas able yo keep the car running for well over 30 seconds. There are no OBD codes except for pending ones. P0101, P3190 og course, P3193 and P0A80. 12 is strong at 13.8 in Ready mode. No P2180 or other throttle body codes and her throttle body is amazingly clean. . Does she have a fuel delivery problem for sure or could it be something else. Weird how much time I have been spending under the Prius hood for the last few wrek but I have learned lots here.
  19. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Check under rear seat to hear if fuel pump is running. If yes, then check fuel pressure under the hood. If theretisvfuel there, you could confirm proper pressure with an external fuel pressure gauge.
    Also would be good if you can confirm voltage of HV battery blocks, voltage of HV battery pack, and HV battery state of charge. (Using torque pro app or similar.
  20. krnluve24
    krnluve24 Junior Member
    Virginia
    2001 Prius
    I am having the exact same issue except I haven't gotten that far to test if it's fuel or spark related. It all happened after an oil change at a gas station which I believe they overfilled it. on the subject of spraying starter fluid, do I just keep spraying onto the throttle plate past the maf sensor while someone else starts the car?
