engine stumbling/running rough while cruising
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mattbatson, Sep 19, 2020.
  1. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    my girlfriends 2010...
    about 8 months ago I did the egr clean on her 230k mile car
    a month ago I was driving it through town and thought I could sense a small amount of rough/misfire type behavior from the motor.
    But I rarely drive it...so dismissed it.
    a week ago she is driving to see me and it starts running rough... enough for her to notice.
    I decide to seafoam the car by injecting the spray directly into the intake manifold.
    Car runs great for a few days then begins to stumble again. Then the yellow triangle light comes on.
    She takes it to the dealer as I'm out of town and they say that the car was due for a software update and that is probably the cause of the problem and she gets out of there without spending a dime.
    Next day the car is running rough again.
    No idea if a code was thrown...if so it was erased at dealer.
    Any ideas?
    thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    How's the engine coolant level?
  3. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    All good with all the levels I’ve been maintaining it for the last year change the PCV valve, etc. Cleaned the MAF about nine months ago etc. pretty sure I change the spark plugs and a few things like that about a year ago also
    Thanks!
    49,458
    you're going to have to read the codes next time the triangle appears.
    did you clean the whole egr circuit?
  5. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I'm out of town and she is on her own for now
    so I could not read anything and she did not get the codes
    I did clean the entire egr circuit...not just the pipe.
    Pretty sure it was the first time the cooler had been cleaned...at 230k miles...and it was mostly clogged...although it was not completly
    this was about a year ago.
    problem cropped up in last couple of weeks
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    You are sure the coolant level is stable?
    SFO likes this.
  7. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Yes
    It was the first thing I checked before spraying in the seafoam
    Immediately I suspected blown head gasket
    So update: She texts to say she is put another 150 miles on the car since it ran rough after leaving the dealer and it seems to be running fine now
    I will update again after a few more days as she is headed to VA (about 5 hours)
    Thanks!
  8. bisco
    49,458
    bad gas?
  9. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    It’s possible of course...
    But in all my years with all the cars I’ve owned... I’ve never had a troubleshoot that involved bad gas
    Doesn’t mean it can’t happen
    But the 3rd gen has so many instances of rough running ...
    But hopefully you are correct and this is what caused it and it’s gone
  10. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    I'm leaning to a HG beginning to fail. I would do a plug and cylinder check for evidence. If none, then maybe one of the COP's is going bad (fingers crossed). Check for codes. Check the oil condition/level. I would stop driving the vehicle, especially long distances, till resolved.
    GOOD LUCK!
    #10 fotomoto, Sep 21, 2020
  11. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Is it possible some residual in EGR (never done this cleaning) plugged it temporarily and now cleared.
    moto g(7) power ?
  12. Mendel Leisk
    38,713
    230k miles without an EGR
    Sorry, what's a COP? Coil?
  13. fotomoto
    5,602
    3,778
    So. Texas
    Coil On Plug. I think the acronym was invented for us, umm, experienced folks who would go looking for coils in others places. LOL
    Mendel Leisk and Raytheeagle like this.
  14. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Okay, now I get the story after rereading. So the dealer reflashed an ECU and it ran rough because it was (re)adapting. Car is now fine, problem solved as dealer expected...
    moto g(7) power ?
  15. Mendel Leisk
    38,713
  16. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Hey
    no ...it was running rough and that is why she took it to the dealer
    That and the yellow triangle
  17. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I suspected as a possibility coil on plug... but from my experience when they go they just go
    and the situation does not get better
    if it starts running rough again though I can check that ....actually have a spare coil on plug in my toolbox
  18. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    I really doubt that... it was at least nine or 10 months ago
    Plus to be honest if there was any residual garbage in the cooler I’m pretty sure it would just blow right out the motor and not cause the engine to stumble for a day or two
  19. mattbatson
    mattbatson Member
    114
    82
    asheville NC
    Thanks
    I will definitely keep an eye on the oil so far it has looked fine
    I’ve considered doing a compression check
  20. Mendel Leisk
    38,713
    Leak-down test will be more revealing.
