engine stumbling
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by legendsguy, Oct 11, 2005.
  1. legendsguy
    legendsguy New Member
    31
    Kalamazoo, MI
    I have a week old '05. I have been noticing it stumble a bit when I come to a stop light. I guess I would describe it as a light shudder as the engine shuts down. I didn't notice this at all the first few days.
    Is this something to worry about or is it normal?
    Doug
  2. kent1915
    kent1915 New Member
    Hey, my '05 is a week old today too. Anyway, mine does it too from time to time, I noted it when it is really cold out (below 35 degrees). No problems with it going after either. I am chalking it up to breaking in, temp, or something benign.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Perfectly normal, PriusChatters. It's the ICE shutting down. It seems to happen at both cold and hot temperatures, particulary if the ICE hasn't warmed up completely yet. Nothing to worry about.
  4. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Ditto in Florida Too
    My Prius TRAC car is a month old and it does the same thing when it first starts in the morning. The problem goes away when the engine warms up (which will take longer up north). It also seems to happen less often than it did a few weeks ago,
  5. shaun
    shaun Junior Member
    I just wanted to chime in on this thread after having read similar posts in the archives. While I too have noticed the occassional rough engine stop at a red light (normal, if still a little disconcerting), I have also noticed it a few times when the ICE kicks back in (normal?).
    Has this happened to anyone else, or is it just me and my leadfoot?
    shaun
    P.S. Slightly off topic, but I was curious if anyone knew if there is some type of mechanism to help keep the oil pressure up in the ICE (e.g., for when you're at a long stop light/train crossing/ or are incredibly lucky and can drive the car solely with the Electric motor for an exorbatant amount of time). My assumption is an electric oil pump that is always running, or something similar that starts back up just before the ICE does to help prevent unecessary wear on the cylinders et. al.
    Hopefully I've explained myself well enough :blink:
    (thanks in advance)
  6. richard schumacher
    7,663
    1,038
    United States
    It has a mechanical oil pump. Self-lubrication is one reason why the engine is spun briefly before compression, fuel, and spark are applied.
  7. c4
    c4 Active Member
    607
    51
    The oil pump in the Prius is non-drain-back trocoid design (vs impeller designs) and provides pretty much instantaneous oil pressure as soon as the drive shaft is turning, so there's no risk of being without lubrication.
  8. endoildependency
    endoildependency New Member
    247
    between Sac/SF CA
    Yep, normal.
  9. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I experience this sometimes...EVEN after the car is fully warmed up and the HV battery is on green bars.
    The shaking is excessive and the ICE seems to keep changing its mind from staying on or off. Sometimes it feels that the ICE will be shutting off, but it shakes a bit and remains on, and eventually goes off.
    It's quite strange, but it does not bother me yet.
  10. Bill Merchant
    4,096
    81
    When your Prius decides it's time to start the ICE, it mechanically, using the electric motor, spins up the engine, without supplying fuel or spark, to about 1000 RPM. Oil pressure goes up then and oil is flowing when spark and fuel are supplied, so no worries about an un-oiled engine when load is applied. I think this is one reason why transition from EV to ICE is so smooth - everything is moving, electirc spinning the ICE until fuel and spark, then ICE spinning the electric generator/motor. The marvel of the Power Split Device.
    The smart Prius needs its HV battery and protects it, not letting it get too high a charge, and turning on the ICE when the charge gets too low. If you have a full green battery (about 80% battery saturation), usually by going down hills with regenerative braking, and then stop, a little too much charge might have been put in the battery. To drain off this excess charge, the Prius uses the electric motor to spin the ICE. The ICE isn't supplying power, it's draining power. Excess electric energy is being used to compress air and blow it out the exhaust. The ICE sounds like it's running, and it cycles on and off, but look at the screen and you'll see a full battery. When the charge is right, the ICE stops cycling.
    Yes, it's very disconcerting the first few times it happens. But normal, don't worry.
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
  12. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    My theory as to why it shudders at stops is because of the miller/atkinson ICE design. Some fuel mixture is pushed back out of the cylinder througth the intake valve into the intake manifold. Some of this fuel vapor may get captured by the charcoal pack in the air cleaner case. So, I believe the engine has its fuel supply cut off, but still provides spark to burn up the residual fuel vapors. In such a situation, it could easily shudder as if it were running out of gas, because it is, on purpose.
  13. lessachs
    lessachs New Member
    Thanks for the info on the engine shudder. I have it happen with my Prius and had worried something was wrong. THe salesman told me this was normal. Hearing it from you folks is reassuring. :)
  14. shaun
    shaun Junior Member
    Thanks (as well) to all who informed me about the rough engine start-up as well as the oil pressure pump. I figured they would've designed something to prevent uneeded engine wear, so it's nice to learn how it all works :)
    Cheers!
    shaun
  15. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    I've had mine for nearly two years. It only happens within the first five minutes of driving. Perfectly normal. :D
  16. momsum
    momsum New Member
    73
    Hudson Valley, NY
    I too, just want to say thanks for the information. I have had this problem with my '05 (3 mos new) and was slightly concerned. Thanks for putting my mind at rest! :)
