Engine Temp
Discussion in 'Gen 2 Prius Main Forum' started by omgitsroy326, Nov 20, 2007.
  1. omgitsroy326
    omgitsroy326 New Member
    267
    Los Angeles
    I have a package 2 08 model.
    How am i suppose to know my engine temp?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You'll need some extra monitoring equipment such as a Scan Gauge II.
  3. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    Yes, Scanguage II or rely on the car to warn you when it got too hot. ;)
  4. daniel
    14,487
    1,518
    Spokane, WA
    You are not "supposed" to know your engine temp. Toyota does not want you to know. Toyota feels that you do not need to know. If your engine overheats, a warning will appear telling you to stop driving immediately.
    But if you want to know, then Evan and David, above, have answered your question.
    Also worth noting that a properly-functioning Prius will never overheat the engine. The car is very smart, and the small engine gets very little stress, due to the functioning of the hybrid system. So there's really no need to worry about engine temp.
  5. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    <div class='quotetop'>QUOTE(omgitsroy326 @ Nov 20 2007, 11:30 PM) [snapback]542285[/snapback]</div>
    What is the normal opeerating temperature range.
  6. LKJR
    LKJR Junior Member
    30
    Delaware
    Using Scan Gauge (and a blocked grill) I range between 180 and 200 F. Mostly its about 190 or so...200 is pretty rare....even on my last trip where I drove about 2 hr non stop at highway speeds between 70 and 75.
