Engine ticking noise
Discussion in 'Prius c Main Forum' started by dragoscscc, Oct 25, 2024.
  1. dragoscscc
    dragoscscc Junior Member
    2001 Prius
    I
    At 00:35, anything to worry about?
    2014 Prius C, about 100k miles, cold start. Runs and drives fine, MPG normal, no lights on the dash.
    Kinda intermittent, only happens when cold. Don't really notice it after it's warmed up or when driving on the highway. Seems to be more noticeable when the engine is coasting and at low speeds. I guess that's when the oil pump would put out the lowest pressure.
    Thinking valves or timing chain/tensioner. Thoughts?
    Thanks,
    D
    52,393
    does the c have an egr?
  3. dragoscscc
    2001 Prius
    I
    yes, I believe the do have an EGR
    52,393
    might be worth cleaning the entire circuit. is the coolant level steady?
    watch
  5. dragoscscc
    2001 Prius
    I
    Coolant and oil are both good, doesn't burn/lose either.
