Engine turning off and on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tylerjames, Dec 29, 2015.
  1. tylerjames
    tylerjames Junior Member
    26
    north bay
    Hello. I understand the engine turns on and off frequently (coming to a stop it turns off, then when going it turns on)
    I have noticed that sometimes when at the stop it will turn off, then immediately back on, and off again, even with my foot on the break. is this normal, or a sign?
    Thanks,
    51,141
    not really. is your battery indicator acting strangely?
    maybe check your 12 volt. is the heat on?
  3. tylerjames
    26
    north bay
    battery indicator seems normal. Yes sometimes my heat is on. Would that cause it to keep the engine on? I thought that was only AC
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Next time it bothers you try turning the heat control setting down to minimum and the engine should turn off and stay off. I've noticed that in winter.
    Sometimes the engine needs to run to generate enough heat. The Prius might run fairly cool in city traffic, if the engine is turned off much of the time.
  5. bisco
    51,141
    it's actually the opposite. the a/c is electric, and the heat needs the engine running. if your on the cusp of a temp cutoff, it might turn on and off, but it shouldn't cycle quickly or often, that would be an anomaly.
    valde3 likes this.
