Engine turning on more often, runs rougher
Discussion in 'Gen 2 Prius Main Forum' started by PublicRadio, Apr 3, 2022.
  1. PublicRadio
    PublicRadio New Member
    Midwest
    I recently had a number of issues come up with my 2007 Prius, which I'll mention at the bottom of this post. But to be concise: the engine tends to come on now when I turn the car on, no matter what. When I first bought the car, that engine never seemed to kick on unless I got up to 30mph, or unless the A/C was on. Now, it's always kicking on.
    It also will turn off at a stop sign, then turn back on again, sometimes even a third time. Also, I don't remember really feeling the engine turn on and off before, and now it's really noticeable.
    So my question is how to diagnose and resolve this issue. Below are some more details about the car:
    1. I parked it on a weird angle, some months back, and that night I had rough idling and a 'check engine' light. The code said a sensor was in the wrong position, but the code went away on its own.
    2. I went too long for an oil change, but only a couple weeks. One morning, I got the big red exclamation mark, towed the car to a dealership, they said the battery was shot and the engine had a misfiring cylinder, and that I was down to a quarter of a quart of oil.
    3. I towed the car home, changed the oil and filter, had Green Bean Battery put a refurbished hybrid battery in it, and the car has run without an engine light ever since.
    4. I recently took the car to a mechanic and told them about the rough engine coming on all the time. I told him I was also feeling abrupt shifting, which is strange because the transmission doesn't have distinct gears. He said a solenoid was going bad on the transmission, replaced that, and the shifting issue is fixed, but the other problem remains.
    49,437
    could be the refurb battery is not up to snuff. any change in mpg's?
    how many miles on her? does the battery icon seem normal?
    run the dr. prius app for module voltages
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,961
    4,709
    Texas Hill Country
    Agree. Bad battery not holding a charge. There are two reasons the engine will run when stopped, the engine is cold and needs to warm up a little - usually only at a coldstart (maybe warming to 120f) OR the hybrid battery is not holding a charge and the engine has to start to recharge it.
    The hybrid battery adds significant power to low and mid speed operation as it runs parallel to the engine. If you don't have any battery power to spare the car will feel sluggish. If the hybrid battery is seriously discharged, the gas engine is really underpowered for acceleration of any type.
  4. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    How long have you owned the car, and how many miles are on it currently?
    Does the HV battery SOC (state of charge) show full (maximum green bars) when you experience this?
    What was that OBD2 code?
    How old is the 12v battery, or when was it last replaced?
    Would be interesting to see the DTC (obd2 code) for that shifting issue, or what the mechanic put down on the invoice for parts etc.
  5. JahT
    JahT Member
    145
    75
    The Check Engine codes should be read, even if the light isn't on. The rough running, is that at idle mainly? It is probably the misfire coming back that was "fixed" before, often times the mechanic changes plugs or coils and it doesn't fix what could be a bad injector or other problem. It does sound like it may be your hybrid battery if your climate controls are off when the engine wants to keep running, I know having the heater on also makes the engine run.
  6. PublicRadio
    Midwest
    These are great answers. I appreciate the help. Sorry, I did not receive any email notifications, or I would have responded sooner. To answer your questions, in order:
    • There are about 150k miles on the car.
    • I'm not sure if there's a change in MPGs. The display says the average is 41mpg, and I've been driving on the new, refurbished battery for 6 months.
    • I don't have the Dr. Prius app, but I'll get it.
    • I've owned the car for about 3.5 years. It had about 106k miles on it when I got it.
    • I will check the SOC indicator the next time this happens.
    • I don't remember the exact engine code but it was very close to this:
      P0024 OBD-II Trouble Code: Camshaft Position B - Timing Over-Advanced or System Performance (Bank 2)
      This was before I replaced the battery, though.
    • The 12v is only 2 years old. I bought it new and replaced it myself.
    • I will check the paperwork to see what the mechanic did with the solenoid.
    • I will check the engine codes and post back.
    • The rough running is roughest when the engine stops. Also when it starts, but especially when it stops.
    I will knock out my to-do items on this list, and I'll check my notification settings to make sure I get any replies. Thanks so much for your help.
    ColoradoCrow, SFO and bisco like this.
