Engine water pump and Inverter pump replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by loklok1, Oct 19, 2021.
  1. loklok1
    loklok1 Junior Member
    44
    Looks like my engine water pump is due for a replacement. Do you guys usually do both the engine water pump and inverter pump at the same time or do you do them separately?
  2. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    How many miles your car has? i don't think it is necessary to replace it, if it's working there is no need to fix. But if you want to do it, well then. My 2012 Prius C has 113,120 miles and still with both original engine coolant pump and inverter coolant pump.
