engine water pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kswahl1, Feb 24, 2014.
  1. kswahl1
    kswahl1 Junior Member
    46
    I've got a grinding noise coming from near my water pump. replaced the serpentine belt w no luck. it's got 212,000 miles one it so I'm guessing the water pump is going bad.
    anyone have any experience with the duralast water pump? it's $40 bucks so I figure I'd give it a try. any info would be great. thanks.
  2. JC91006
    16,474
    8,393
    The noise might not be coming from the water pump, it could be the idler pulley bearings. If you are going to take everything apart, replacing the water pump at that mileage is also recommended.
    You should try to get the OEM part, it sells on Amazon.com under AISIN water pump for Prius. It's about $44.00.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Don't buy the duralast. Get an Aisin water pump instead, which is OEM. Get it at Amazon for $43.98 + free shipping. Amazon.com: Aisin WPT-111 Engine Water Pump: Automotive
  4. kswahl1
    46
    I spun the idler pulley and it wasn't clicking or anything. do dealers keep pumps in stock? if so how much do they usually charge?
  5. kswahl1
    46
  6. JC91006
    16,474
    8,393
    Yes the pumps should be in Stock, from $60 to $70
    SM-N900P ?
  7. kswahl1
    46
    cool. thanks for your help.
  8. JC91006
    16,474
    8,393
    You will need to get some super long life coolant too. That's about $22 dollars a gallon
    SM-N900P ?
  9. dpeverhart
    dpeverhart Member
    126
    23
    I
    I just had one replaced with a water pump from Advance Auto Parts. I believe it was GMB brand. Lists for $39 with coupon code TRT30 (30% discount) it was just under $30.
  10. kswahl1
    46
    I just replaced the coolant two months ago. will all the coolant come out when I take off the pump?
  11. JC91006
    16,474
    8,393
    You don't want to end up short on coolant. If you live in a mild climate, you can possibly top off with a little distilled water. Air in your coolant loop can cause many problems. I would recommend getting a gallon of super long life coolant
    SM-N900P ?
  12. kswahl1
    46
    nice. not sure you can go wrong at that price.thanks for the code.
  13. JC91006
    16,474
    8,393
    There can be lots that go wrong with a failed water pump. I wouldn't recommend a pump from China for your prius
    SM-N900P ?
  14. Patrick Wong
    18,200
    6,471
    "I just replaced the coolant two months ago. will all the coolant come out when I take off the pump?"
    Yes. You can drain the coolant at the radiator drain plug and catch a gallon in a clean container, then reuse it. However you should still have a gallon of Toyota SLLC available if you need it.
    I agree with the recommendation that you purchase an Aisin-brand pump (Aisin is the original equipment manufacturer) if you don't wish to purchase a Toyota-branded pump. The Aisin pump is quite inexpensive and the quality and service life of the cheaper alternatives is questionable.
  15. Rich12
    Rich12 Member
    176
    29
    Hint: Use a gear ratcheting 10mm wrench to get the pulley bolts off.
