Engine water pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KJ Fitz, May 25, 2022.
  1. KJ Fitz
    KJ Fitz Junior Member
    55
    Guam
    I have a nice 2015 Gen 3. Only 70,000 miles (II live on Guam, you can't drive very far without falling in the ocean). Got a check engine light today, code P261b, appears the water pump is failing. Obviously I won't drive it, and will replace the pump. Is there a gasket I need to order, too? Anything tricky about draining and replacing the coolant?
  2. ChapmanF
    18,256
  3. KJ Fitz
    55
    Guam
    Perfect, thank you!
  4. Mendel Leisk
    41,545
    Worth replacing the thermostat too?
    xliderider likes this.
  5. KJ Fitz
    55
    Guam
    Good call, ordered new thrmostat and housing as well as the pump.
  6. ASRDogman
    ASRDogman Senior Member
    7,618
    3,923
    Doesn't hurt to change the thermostat also.
    Fill S L O W L Y! And you shouldn't have a problem.
